System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=42fbe969-cb6d-44e9-a405-371f731e43c7
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
Mobo: HP model: 86D4 v: 96.45 serial: <superuser required> UEFI: AMI v: F.12 date: 12/21/2020
Battery: ID-1: BAT0 charge: 39.5 Wh (100.0%) condition: 39.5/39.5 Wh (100.0%) volts: 12.7 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full cycles: 355
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L1: 384 KiB
L2: 2 MiB L3: 4 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33538
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397
Graphics: Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] vendor: Hewlett-Packard driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c91 class-ID: 0300
Device-2: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Audio: Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x bus-ID: 05:00.5
Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: e000 bus-ID: 03:00.0 chip-ID: 10ec:c822
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 7 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 1.14 TiB used: 974.97 GiB (83.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: AGHA4101 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
serial: <filter> rev: RPM2 scheme: GPT
Partition: ID-1: / raw-size: 44.89 GiB size: 44.89 GiB (100.00%) used: 36.21 GiB (80.7%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 94.2 MiB (36.8%) fs: vfat
ID-3: /home raw-size: 44.89 GiB size: 44.89 GiB (100.00%) used: 36.21 GiB (80.7%) fs: btrfs
ID-4: /var/log raw-size: 44.89 GiB size: 44.89 GiB (100.00%) used: 36.21 GiB (80.7%) fs: btrfs
ID-5: /var/tmp raw-size: 44.89 GiB size: 44.89 GiB (100.00%) used: 36.21 GiB (80.7%) fs: btrfs
ID-1: swap-1 type: zram size: 5.73 GiB used: 178.9 MiB (3.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 48 C device: amdgpu temp: 52.0 C
Info: Processes: 302 Uptime: 1d 12h 24m wakeups: 7 Memory: 5.73 GiB used: 3.34 GiB (58.2%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1502 lib: 340 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.09
try install Arch Linux - cuda 11.5.1-1 (x86_64)
i installed a bunch of packs for compute to run also a whole bunch of Vulkan packs but now all seems to work
Thanks, it worked, i wasnt able to figure out whats the cuda package for arch was. Thanks again
