Has anyone else lost optix as a choice in blender 3.0 as a cycles render option
I,ve seem to have lost it on my laptop and my desktop pc?
My inxi of my laptop
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=254c08ed-2f9a-4d57-8d98-9b56a52c327f rw
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Micro-Star product: GL65 Leopard 10SFR v: REV:1.0 serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Micro-Star model: MS-16U7 v: REV:1.0 serial: <superuser required> UEFI: American Megatrends v: E16U7IMS.10A
date: 07/17/2020
Battery: ID-1: BAT1 charge: 41.5 Wh (100.0%) condition: 41.5/51.6 Wh (80.5%) volts: 12.0 min: 10.9 model: MSI BIF0_9
type: Li-ion serial: N/A status: Full
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165)
stepping: 2 microcode: EA cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4637 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4637 2: 4797 3: 4549 4: 4713 5: 4621 6: 4721 7: 4791
8: 4755 9: 4877 10: 4801 11: 4528 12: 4801
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh] vendor: Micro-Star MSI driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f14 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:4 chip-ID: 04f2:b695 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Monitor-1: eDP-1-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 931.51 GiB used: 167.15 GiB (17.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 33.9 C
Partition: ID-1: / raw-size: 428.71 GiB size: 428.71 GiB (100.00%) used: 167.12 GiB (39.0%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 27.6 MiB (28.7%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 428.71 GiB size: 428.71 GiB (100.00%) used: 167.12 GiB (39.0%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 428.71 GiB size: 428.71 GiB (100.00%) used: 167.12 GiB (39.0%) fs: btrfs
ID-5: /var/tmp raw-size: 428.71 GiB size: 428.71 GiB (100.00%) used: 167.12 GiB (39.0%) fs: btrfs
ID-1: swap-1 type: zram size: 15.44 GiB used: 4.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.0 C pch: 47.0 C mobo: N/A gpu: nvidia temp: 42 C
Info: Processes: 351 Uptime: 1h 31m wakeups: 1 Memory: 15.44 GiB used: 4.13 GiB (26.8%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1914 lib: 558 Shell: fish v: 3.3.1
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09~~~
