Blender 5.1 refuse to load
Hi, Txemi Jendrix here.
I’ve just updated Garuda today and Blender 5.1 refuse to load.
I’ve tried running it from a console and it says this:
╰─λ blender
blender: error while loading shared libraries: libopenjph.so.0.24: cannot open shared object file: No such file or directory
I’ve searched for libopenjph and these are the results
/usr/lib/libopenjph.so
/usr/lib/libopenjph.so.0.26
/usr/lib/libopenjph.so.0.26.3
So there is a version mismatch here. Any advice? TIA
My garuda-inxi
× garuda-inxi
  Kernel: 6.18.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=bfccf572-5f15-43dc-b9e0-df4cc01ba194 rw rootflags=subvol=@
    quiet loglevel=3
  Desktop: KDE Plasma v: 6.6.1 tk: Qt v: N/A info: frameworks v: 6.23.0
  Type: Laptop System: NA product: AX16PRO v: Version 1.0
    serial: <superuser required> Chassis: SU type: 10
  Mobo: NA model: AX16PRO v: Version 1.0 serial: <superuser required>
    part-nu: NA uuid: <superuser required> Firmware: UEFI vendor: American
    Megatrends LLC. v: 2.15 date: 07/05/2024
  ID-1: BAT0 charge: 29.7 Wh (57.1%) condition: 52/53.6 Wh (97%) volts: 11.2
    min: 11.4 model: Standard SR Real Battery type: Li-ion serial: <filter>
    charging: status: discharging cycles: N/A
  Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA500012
  Speed (MHz): avg: 1096 min/max: 411/4548 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1096 2: 1096 3: 1096
    4: 1096 5: 1096 6: 1096 7: 1096 8: 1096 9: 1096 10: 1096 11: 1096 12: 1096
    13: 1096 14: 1096 15: 1096 16: 1096 bogomips: 63880
    ssse3 svm
  Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: IP3 Tech
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 03:00.0 chip-ID: 1002:15e7
    class-ID: 0300 temp: 31.0 C
  Device-2: Alcor Micro PC Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 058f:3863
    class-ID: 0102
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
    display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,left model: HP P222va serial: <filter>
    built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2
    max: 1920x1080 min: 640x480
  Monitor-2: eDP-1 pos: right model: BOE Display 0x06f9 built: 2016 res:
    mode: 1920x1080 hz: 60 scale: 130% (1.3) to: 1477x831 dpi: 142 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.1-arch1.1
    renoir ACO DRM 3.64 6.18.13-zen1-1-zen) device-ID: 1002:15e7
  API: Vulkan v: 1.4.341 layers: 6 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.0.1-arch1.1
    device-ID: 1002:15e7 surfaces: N/A device: 1 type: cpu name: llvmpipe
    (LLVM 21.1.8 256 bits) driver: mesa llvmpipe v: 26.0.1-arch1.1 (LLVM
    21.1.8) device-ID: 10005:0000 surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor driver: N/A
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
    snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    vendor: Conexant Systems driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Alcor Micro PC Camera driver: snd-usb-audio,uvcvideo type: USB
    class-ID: 0102
  API: ALSA v: k6.18.13-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2:2 chip-ID: 0bda:8156
  IF: enp3s0f3u2 state: up speed: 100 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0bda:b85b
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 sub-v: 4e04 hci-v: 11 rev: 42d3 class-ID: 7c010c
  Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
    link-mode: peripheral accept service-classes: rendering, capturing, object
    transfer, audio, telephony
  Local Storage: total: 476.94 GiB used: 177.63 GiB (37.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: RS512GSSD510 size: 476.94 GiB
    tech: SSD serial: <filter> fw-rev: SN13126 temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 374.84 GiB size: 374.84 GiB (100.00%)
    used: 177.6 GiB (47.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 31.6 MiB (32.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 374.84 GiB size: 374.84 GiB (100.00%)
  ID-4: /var/log raw-size: 374.84 GiB size: 374.84 GiB (100.00%)
  ID-5: /var/tmp raw-size: 374.84 GiB size: 374.84 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.01 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 33.2 C mobo: N/A gpu: amdgpu temp: 32.0 C
  Memory: total: 16 GiB note: est. available: 15.01 GiB used: 4.3 GiB (28.7%)
  Processes: 387 Power: uptime: 29m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1593 libs: 405 tools: octopi,paru Compilers:
    clang: 21.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
    inxi: 3.3.40
Garuda (2.12.3-2):
  System install date:     2024-12-27
  Last full system update: 2026-03-02
25/26 checks run in 1.35 seconds ⌛
Powered by garuda-health 🦅
Looks like it’s been notified:
Coming from:
Fine.
I’ve downloaded Blender and installed it in my user directory as a quick solution.
Thanks for the info.
Bye
