Recently System showing only mouse after idle screen timeout, only a pointer along with with blank screen, I have two computers both loaded with xfce garuda both have same problem.
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=dfa1be8c-fda6-4390-916c-0d430d43780c rw rootflags[email protected]
Type: Laptop System: LENOVO product: 20Q5S0PR00 v: ThinkPad L490
Mobo: LENOVO model: 20Q5S0PR00 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R0ZET50W (1.28 )
date: 02/10/2022
ID-1: BAT0 charge: 42.0 Wh (98.6%) condition: 42.6/45.0 Wh (94.8%)
volts: 12.3 min: 11.1 model: LGC 5B10W138 type: Li-poly serial: <filter>
status: not charging cycles: 44
Info: model: Intel Core i5-8365U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
stepping: 0xC (12) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1750 high: 1900 min/max: 400/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1900 2: 1900 3: 1900
4: 1900 5: 1900 6: 700 7: 1900 8: 1900 bogomips: 30399
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: HDMI-A-1 off: eDP-1 empty: DP-1,DP-2,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:5 chip-ID: 04f2:b6d9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary
model: ViewSonic VX3276-QHD serial: <filter> built: 2021 res: 2560x1440
hz: 60 dpi: 93 gamma: 1.2 size: 698x393mm (27.48x15.47")
diag: 801mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 note: disabled model: BOE Display 0x0791 built: 2017
res: 2560x1440 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound API: ALSA v: k6.2.6-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
v: 0.8 bus-ID: 1-6:3 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 476.94 GiB used: 129.58 GiB (27.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1001 size: 476.94 GiB block-size: physical: 512 B
rev: 11170101 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 246.21 GiB size: 246.21 GiB (100.00%)
used: 129.55 GiB (52.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
used: 36.3 MiB (14.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 246.21 GiB size: 246.21 GiB (100.00%)
maj-min: 259:4
ID-4: /var/log raw-size: 246.21 GiB size: 246.21 GiB (100.00%)
maj-min: 259:4
ID-5: /var/tmp raw-size: 246.21 GiB size: 246.21 GiB (100.00%)
maj-min: 259:4
ID-1: swap-1 type: partition size: 10.74 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.41 GiB used: 64.5 MiB (0.9%) priority: 100
System Temperatures: cpu: 60.0 C pch: 55.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2800 fan-2: 2800
Processes: 321 Uptime: 1h 20m wakeups: 25 Memory: 7.41 GiB
used: 4.84 GiB (65.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1840
pm: pacman pkgs: 1808 libs: 422 tools: octopi,pamac,paru,yay pm: flatpak
pkgs: 32 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-02-08
Last full system update: 2023-03-16
