Blackarch not downloading
If I try to download blackarch it says “blackarch: signatures from “levon ‘noptrix’ Kayan (blackarch developer) [email protected]” is unknown trust”
You need to update the package signing key.
See also:
:point_up:
If above doesn’t work or you probably wanna try something shorter,
go into /etc/pacman.d/blackarch-mirrorlist
You will find servers that have # before them, [This are commented out] and those that don’t which are the ones currently working.
example:
#Server = ftp:some-server-giving-you-headache/$repo/os/$arch
Now you can choose to comment those that are not commented, i.e adding a # symbol in front of them while updating, until you find the non working server. Or Comment all the ones that are uncomment and uncomment 1 by 1 till you get working servers.
I think I may have complicated myself.
