Hello i have not updated my system in a while
Today i did a upgrade and after i login i get a black screen with a cross cursos
I had to roll back my system to come here and post this message.
please help
please help
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Kernel: 6.4.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fb4f8752-5778-428b-984d-80e7a1caddca rw rootflags=subvol=@
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Micro-Star model: MPG Z390 GAMING EDGE AC (MS-7B17)
v: 2.0 serial: <superuser required> UEFI: American Megatrends v: A.70
date: 01/02/2020
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF8
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4348 high: 4801 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 4792 2: 4800 3: 4800
4: 4800 5: 4796 6: 4009 7: 4760 8: 3600 9: 3230 10: 4800 11: 4801 12: 3600
13: 3600 14: 4794 15: 4800 16: 3600 bogomips: 115200
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: ASUSTeK driver: nvidia
v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2786 class-ID: 0300
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-4 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x12.99")
diag: 865mm (34.07") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
4070/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
Device-3: EVGA NU Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 3842:3100
class-ID: fe01
API: ALSA v: k6.4.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9
address: <filter>
Local Storage: total: 12.26 TiB used: 10.08 TiB (82.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 48.9 C
model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 48.9 C scheme: GPT
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Zotac model: ZTSSD-A5P-480G-PE
tech: SSD serial: <filter> fw-rev: 01.6 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD4003FZEX-00Z4SA0 size: 3.64 TiB block-size: physical: 4096 B
used: 705.9 GiB (75.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 62.73 GiB used: 1.52 GiB (2.4%)
System Temperatures: cpu: 47.0 C pch: 71.0 C mobo: N/A gpu: nvidia
temp: 52 C
Processes: 435 Uptime: 1d 21h 47m wakeups: 0 Memory: total: 64 GiB
note: est. available: 62.73 GiB used: 13.65 GiB (21.8%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1497 libs: 453 tools: pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.28
System install date: 2024-02-24
Last full system update: 2023-07-22
Is partially upgraded: Yes
Try repeating the garuda-update and then check and merge the pacdiffs before rebooting. At least those which seem more important. There might be many diffs after so much time. Use e.g.
sudo -E DIFFPROG=meld pacdiff
If that doesn’t help, switch to a TTY and check logs, failed services, etc.
Consider also:
A partially upgraded system is in a fragile state. Fix this and you may be okay.
