Hello !
Currently i am using on my notebook with Ryzen 5500u the linux amd Kernel. I have there a better performance then with Linux-Zen Kernel because it can throttle the CPU down to 400 Mhz while Linux-Zen and Mainline LTS kernels can do this only to 1400 Mhz.
Usage Linux Zen:
Compare Usage Linux amd: "Linux 5.19.12-AMD #1 SMP PREEMPT_DYNAMIC Thu Sep 29 10:16:58 CEST 2022 x86_64"
I know that this issue could be more at a problem of kernel.org or linux-zen actors but i just wanted to show it up here maybe someone can forward it to right direction.
Best regards
Hi @Mr.Ryzen, I'm glad you found a kernel you are happy with.
It is unclear what the issue or request is. Are you wishing for all other kernels to to be optimized for your specific hardware, like the linux-amd kernel is?
oh no but i think this feature could be very energy saving special on notebooks because the battery will live longer and this Kernel is not available as binary so it has to be compiled.
I am sure this is not diffcult to enable by default also in Mainline Kernels.
And Garuda wants to be very userfriendly so userfriendly is also when the battery lives longer.
Maybe you could move my thread to the right section of this forum.
And i wanted to start here before requesting at the kernel-developers because for this i am too much noob.
I have been using Linux since very long time starting with Linux Mint and Ubuntu and Debian.... but honestly said i can not discuss with this Liga because i can not say which switch of the [config.x86_64] is different to Mainline-Kernels.
This is also the reason why i request here and i am sure there are throttle-potentials for Intel-Cpus as well.
