I use garuda-update and I am happy to use it.
Is it better
sudo su -
garuda-update
or as user with high privileges (admin)
garuda-update
and insert user password.
my garuda-inxi is
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209 rw rootflags=subvol=@
quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878 splash
resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A
Mobo: FUJITSU model: FJNBB35 serial: <superuser required>
UEFI: FUJITSU // Phoenix v: Version 1.13 date: 11/18/2013
ID-1: BAT0 charge: 0.9 Wh (100.0%) condition: 0.9/4.5 Wh (20.1%)
volts: 12.2 min: 10.8 model: PTL CP651527-01 type: Li-ion serial: <filter>
status: N/A cycles: 274
Info: model: Intel Core i7-4702MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2193 high: 2200 min/max: 800/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2195 2: 2196 3: 2195
4: 2200 5: 2195 6: 2171 7: 2196 8: 2196 bogomips: 35118
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu
driver: i915 v: kernel ports: active: HDMI-A-1 off: eDP-1 empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: Importek FJ Camera type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 10f1:1a58 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
alternate: fbdev,intel,vesa gpu: i915 display-ID: 0
OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
v: 4.6 Mesa 22.1.0 direct render: Yes
vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
vendor: Fujitsu driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
bus-ID: 1-8:7 chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: down
address: <filter>
Local Storage: total: 931.51 GiB used: 106.28 GiB (11.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
used: 106.28 GiB (11.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
used: 682 KiB (0.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 1.2 GiB (15.6%)
mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
System Temperatures: cpu: 70.0 C pch: 62.0 C mobo: 27.8 C
Processes: 311 Uptime: 1d 13h 30m wakeups: 13 Memory: 7.67 GiB
used: 2.77 GiB (36.2%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1738 lib: 385 Shell: fish
v: 3.4.1 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-03-13
Last full system update: 2022-06-03 ↻
