First off, I'm new to tiling WMs and Garuda, but not Linux or Arch. I'm running the latest build (as of Feb-23-2023) on my Thinkpad X1 which has a resolution of 3840*2160, and I'm struggling to find anywhere where I can hopefully "universally" set some scaling value so that the QTile bar is actually legible.
I see the line in init_screens() that sets the "size" of the top bar, but obviously that doesn't magically scale all the other widgets in kind.
Is there instead / also a value that I should be putting into init_widgets_defaults() to affect all the widgets? Or is this something I would have to apply to each widget individually?
Or does changing the font "fill" the height and width dynamically?
As far as I can tell, I vaguely understand what the config.py is doing, I'm just trying to wrap my head around what values affect what without super-duper breaking everything at the same time.
I would really appreciate someone pointing me in the direction of which values in the config are what I'm looking for.
Alternatively, if someone else has already got a near-default config that accounts for 4K screens, I would gladly accept that as well.
Also as required, below is my inxi output, and please let me know if there's any more info I should provide to make this easier to assist me with.
Thanks.
root=UUID=5d3945a3-3f19-4cfa-8da6-0c9c247f285e rw [email protected]
resume=UUID=554b6356-1fa7-4039-8727-185b8153e01b loglevel=3
Desktop: Qtile v: 0.22.1 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 20MF000MUS v: ThinkPad X1 Extreme
Mobo: LENOVO model: 20MF000MUS v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N2EET41W (1.23 )
date: 07/03/2019
ID-1: BAT0 charge: 68.1 Wh (100.0%) condition: 68.1/80.4 Wh (84.7%)
volts: 17.1 min: 15.4 model: Celxpert 01AY969 type: Li-poly serial: <filter>
status: full cycles: 102
Device-1: wacom_battery_0 model: Wacom Pen and multitouch sensor
serial: N/A charge: 0% rechargeable: yes status: N/A
Info: model: Intel Core i7-8850H bits: 64 type: MT MCP arch: Coffee Lake
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1850 high: 2600 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 2600 3: 2600
4: 800 5: 2600 6: 800 7: 800 8: 2600 9: 2600 10: 800 11: 2600 12: 801
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
Device-3: Bison Integrated IR Camera type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 5986:2123 class-ID: 0e02
Device-4: Bison Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2
chip-ID: 5986:2115 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-c4107
driver: X: loaded: modesetting,nvidia unloaded: nouveau
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.61x14.96")
s-diag: 775mm (30.53")
Monitor-1: eDP-1 model: AU Optronics 0x32eb built: 2017 res: 2560x1440
dpi: 189 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 15.24 GiB (3.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN720
SDAQNTW-512G-1001 size: 476.94 GiB block-size: physical: 512 B
rev: 10190101 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
used: 15.24 GiB (3.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
ID-4: /var/log raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.05 GiB used: 768 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 46.0 C pch: 49.0 C mobo: N/A
Processes: 308 Uptime: 42m wakeups: 5 Memory: 15.05 GiB
used: 3.1 GiB (20.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1209
libs: 332 tools: pamac,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-24
Last full system update: 2023-02-24 ↻
inxi.txt
7 KB
