Hello everyone. I attempted to compile a rather large game (quake3-rally) with a lot of dependencies that installed along with it. Is there a way to safely uninstall all that was acquired during the compile with a single command without having to go through the terminal history and naming each package individually? Sometimes I can’t even get to the terminal history because of closing the terminal. I’ve read man pacman on it but I’m nervous to experiment after reading. I retried the compile many times after finding and installing dependencies that paru couldn’t seem to find, and I tried to compile with both paru and with makepkg, getting some dependencies with both. So, the package list would be a cluster-mess to get together.
Or, maybe there’s a better way I could do in the future to compile that would make it easier to get rid of it all. I’m all ears. I just don’t want to be left with gigabytes of stuff I’ll never use again, but if that’s the answer please let me know. I really have no idea.
I’m hoping for something simple like
sudo pacman -Rsc quake3-rally
except that quake3-rally never actually got installed…
or, maybe the best answer is to take a snapshot before the compile that I could revert to.
EDIT: Now that I think about it, it probably made spapshots a few times automatically. Is reverting to a snapshot the best answer?
Thank you for any help or insight.
╭─user@gbox in ~
╰─λ garuda-inxi
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e18dd1e4-3ee8-4352-8bd3-58066522e6ff rw rootflags=subvol=@
quiet loglevel=3 modprobe.blacklist=iTCO_wdt ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: Dell product: Precision 7510 v: N/A
Mobo: Dell model: N/A serial: <superuser required> part-nu: 06D9
uuid: <superuser required> UEFI: Dell v: 1.31.3 date: 03/09/2023
ID-1: BAT0 charge: 67.6 Wh (100.0%) condition: 67.6/91.0 Wh (74.3%)
volts: 12.9 min: 11.4 model: Samsung SDI DELL TWCPG77 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-6820HQ bits: 64 type: MT MCP arch: Skylake-S
Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_pstate
8: 800 bogomips: 43198
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-4, DP-5, DP-6, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 0000:00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107GLM [Quadro M2000M] vendor: Dell driver: nvidia
v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 ports: active: none
empty: DP-1, DP-2, DP-3, VGA-1 bus-ID: 0000:01:00.0 chip-ID: 10de:13b0
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4 chip-ID: 0bda:5686
Monitor-1: eDP-1 res: 1829x1029 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:191b memory: 15.19 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: integrated-gpu
name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 24.2.3-arch1.1
device-ID: 8086:191b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: Quadro M2000M driver: nvidia v: 560.35.03
device-ID: 10de:13b0 surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.2.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 0000:00:1f.3
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:0fbc
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel
bus-ID: 0000:02:00.0 chip-ID: 8086:24f3 class-ID: 0280
Hardware-1: Intel SATA Controller [RAID mode] driver: intel_nvme_remap
v: N/A port: f060 bus-ID: 0000:00:17.0 chip-ID: 8086:2822 rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 25.94 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S690Q 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: VF001C30 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 32 GiB size: 32 GiB (100.00%) used: 21.62 GiB (67.6%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 27.4 MiB (2.7%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 447.65 GiB size: 447.65 GiB (100.00%)
used: 4.3 GiB (1.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 32 GiB size: 32 GiB (100.00%)
used: 21.62 GiB (67.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/tmp raw-size: 32 GiB size: 32 GiB (100.00%)
Kernel: swappiness: 2 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 31.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C pch: 48.5 C mobo: 46.0 C
Fan Speeds (rpm): cpu: 2623 fan-2: 2614
Memory: total: 32 GiB available: 31.11 GiB used: 4.67 GiB (15.0%)
Processes: 310 Power: uptime: 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1933 libs: 547 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-09-20
Last full system update: 2024-09-23
Is partially upgraded: Notype or paste code here
