Best way to install Conky for KDE D460nized
Hi Everyone,
What is the best way to install & get Conky working with Garuda? I've never worked with it before & am kind of confused. I originally installed it with:
pacman -S conky conky-manager
but then read through some things in the Forum, & ended up trying to compile conky-lua-nv via:
git clone https://aur.archlinux.org/conky-lua-nv.git.
After doing that, it said that the regular conky package was in conflict, so I just let it remove that one. There is a .conky folder in my home directory, and the conky.desktop file is in /etc/xdg/autostart.
Now I'm unsure what to do from here. I am using the KDE Dr460nized version, & have read that Conky can be tricky to get working right with Plasma. What's the best way to go about doing everything?
Kernel: 6.1.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=219f04f8-c9e0-400f-9d0d-043e8bfeff04 rw [email protected]
quiet
cryptdevice=UUID=52208f8d-eb2d-4f13-aa58-a362bbe116ae:luks-52208f8d-eb2d-4f13-aa58-a362bbe116ae
root=/dev/mapper/luks-52208f8d-eb2d-4f13-aa58-a362bbe116ae splash
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 0Y1K2K v: A01 serial: <superuser required> UEFI: Dell
v: 1.4.1 date: 09/08/2021
ID-1: BAT0 charge: 88.3 Wh (100.0%) condition: 88.3/95.1 Wh (92.9%)
volts: 12.4 min: 11.4 model: BYD DELL F8CPG1A type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x42
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2361 high: 3276 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 2300 8: 2300 9: 2300 10: 2300 11: 2300 12: 2300
13: 2300 14: 2300 15: 3276 16: 2300 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0302
Display: x11 server: X.Org v: 21.1.5 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: i965 gpu: i915
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.00x25.00")
s-diag: 1198mm (47.17")
Monitor-1: eDP-1 mapped: eDP1 model: Sharp 0x1517 built: 2021
res: 3840x2400 hz: 60 dpi: 264 gamma: 1.2 size: 370x230mm (14.57x9.06")
diag: 432mm (17") ratio: 16:10 modes: 3840x2400
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
chip-ID: 8086:43c8 class-ID: 0401
Sound API: ALSA v: k6.1.0-zen1-1-zen running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: Waifu state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-4.1:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u4u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br10 state: down mac: <filter>
bus-ID: 3-14:3 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 476.94 GiB used: 374.24 GiB (78.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 41001131 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
used: 374.24 GiB (78.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-52208f8d-eb2d-4f13-aa58-a362bbe116ae
used: 738 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.36 GiB used: 1 GiB (6.5%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 389 Uptime: 2h 55m wakeups: 30330 Memory: 15.36 GiB
used: 6.48 GiB (42.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages:
pm: pacman pkgs: 1636 libs: 353 tools: pamac,paru,trizen,yay Shell: fish
v: 3.5.1 default: Zsh v: 5.9 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date:     2022-01-08
Last full system update: 2022-12-20 ↻
Is partially upgraded:   Yes
Snapshots:               Timeshift
Failed units:            shadow.service
Hi,
First of all, you have to edit PKGBUILD file in the folder where you downloaded the conky-lua-nv source, and edit line
MAINTAINER_MODE=ON
to
MAINTAINER_MODE=OFF
and save and exit.
Now, in the same folder, open terminal and run
makepkg -rsf
This should take some time and make a tarball called conky-lua-nv-.... where .... would be the version ( it is conky-lua-nv-1.15.0-1-x86_64.pkg.tar.zst for me right now).
So, now, all you have to do is
sudo pacman -U conky-lua-nv-1.15.0-1-x86_64.pkg.tar.zst
or replace the name with exact version.
Now you have conky-lua-nv installed.
What do you want to do now? I mean which theme?
Hey there :slight_smile:
Okay, I restored a snapshot back to before compiling conky-lua-nv, so I could "start over" so to speak.
This is the PKGBUILD file:
# Maintainer: Spyros Stathopoulos <foucault.online[at]gmail[dot]com>
# Contributor: Jon Wilson <[email protected]>
# Contributor: Andrwe Lord Weber <lord-weber-andrwe [at] andrwe [dot] org>
# Contributor: Giovanni Scafora <[email protected]>
# Contributor: James Rayner <[email protected]>
# Contributor: Partha Chowdhury <[email protected]>
pkgname=conky-lua-nv
_pkgname=conky
pkgver=1.15.0
pkgrel=1
pkgdesc="An advanced system monitor for X based on torsmo with lua and nvidia enabled"
arch=('i686' 'x86_64')
url="https://github.com/brndnmtthws/conky"
license=('GPL' 'BSD')
replaces=('torsmo' 'conky')
conflicts=('conky')
provides=('conky' 'conky-lua')
depends=(
  'glibc' 'glib2' 'lua' 'wireless_tools' 'libxdamage' 'libxinerama' 'libxft' 'imlib2'
  'libxml2' 'libpulse' 'libxnvctrl' 'systemd-libs' 'ncurses' 'curl'
  libncursesw.so libXNVCtrl.so libsystemd.so libpulse.so libcurl.so
makedepends=('cmake' 'docbook2x' 'docbook-xsl' 'man-db' 'git' 'catch2'
             'pandoc' 'python-yaml' 'python-jinja')
optdepends=('nvidia: for GT4xx and newer GPUs',
  'nvidia-340xx: for G8x, G9x, GT2xx GPUS',
  'nvidia-304xx: for GeForce 6/7 GPUs')
source=("https://github.com/brndnmtthws/${_pkgname}/archive/v${pkgver}.tar.gz")
sha1sums=('75ae3d65dbe155219cbfdd78b52e3c3e8615285b')
options=('!strip' 'debug')
install='conky-lua-nv.install'
prepare() {
  # disable HSV gradients for now
  cd ${srcdir}/${_pkgname}-${pkgver}
  rm -r tests/catch2
  ln -s /usr/include/catch2 tests
build() {
  cmake \
    -B build \
    -D CMAKE_BUILD_TYPE=Release \
    -D CMAKE_CXX_FLAGS="$CXXFLAGS -ffat-lto-objects" \
    -D MAINTAINER_MODE=ON \
    -D BUILD_DOCS=ON \
    -D BUILD_IMLIB2=ON \
    -D BUILD_EXTRAS=ON \
    -D BUILD_LUA_RSVG=ON \
    -D BUILD_LUA_CAIRO=ON \
    -D BUILD_LUA_IMLIB2=ON \
    -D BUILD_WLAN=ON \
    -D BUILD_XDBE=ON \
    -D BUILD_XSHAPE=ON \
    -D BUILD_HSV_GRADIENT=ON \
    -D BUILD_CURL=ON \
    -D BUILD_RSS=ON \
    -D BUILD_NVIDIA=ON \
    -D BUILD_WEATHER_METAR=ON \
    -D BUILD_PULSEAUDIO=ON \
    -D BUILD_JOURNAL=ON \
    -D CMAKE_INSTALL_PREFIX=/usr \
    -Wno-dev \
    -S .
  make -C build
package() {
  make -C build DESTDIR=${pkgdir} install
  install -D -m644 COPYING -t ${pkgdir}/usr/share/licenses/${pkgname}
  install -D -m644 build/extras/vim/syntax/conkyrc.vim -t "${pkgdir}"/usr/share/vim/vimfiles/syntax/conkyrc.vim
  install -D -m644 extras/vim/ftdetect/conkyrc.vim -t "${pkgdir}"/usr/share/vim/vimfiles/ftdetect/conkyrc.vim
# vim:ts=2:et:sw=2
Should I recompile it again to be able to see the MAINTAINER_MODE=ON part? My guess is that wouldn't make sense, but just not seeing it in here. I got it from the AUR
[EDIT]: I'm a moron, lol... just saw it :woman_facepalming: :sweat_smile:
Okay, well, before I go trying to pick themes, what should I be doing next?
I still can't find the conky.conf file anywhere.
If I run conky-manager, it looks like there are some theme type entries in there. Simply checking the boxes next to them doesn't result in all of them showing up on the desktop, to be edited further or otherwise.
And of the ones that do, there is often this screen tearing effect within the widget display.
Should I also install conky-cairo?
Nothing......
Just pick up the theme and follow their guide
Nope
Ended up just trying to follow a ChrisTitus video where he shows how to edit a script he downloaded.
Since I couldn't figure out how the conky-lua-nv was working, I just started over & dealt straight with Conky. No conky-manager or anything else.
Once I got the script modified the way I wanted as far as colors & things like that, I put it into the ~/.conky folder. Then did his suggestion to make a symbolic link for it in /etc/profile.d to have it run on startup. conky.desktop was already in /etc/xdg/autostart, and it seemed to be loading up on startup just fine like that before doing the sym link. But I guess that covers it in some additional way. I'm not sure I fully understand the implications of adding the sym link.
But for now, it's working, Lol <: D
As far as other places to find more conky scripts/configs, a lot of people have suggested DeviantArt... which has tons of amazing looking ones. But now everything is paywalled, it's not the site I remember browsing to for wallpapers 20+yrs ago, lol :joy:
Aside from r/conkyporn, are there any other good places anyone might recommend?
