nik
12 September 2023 11:32
1
Hi,
I’m having some problems with my setup where the OS freezes several times per week. Usually it’s accompanied with the Caps Lock LED blinking (kernel panic I guess).
Please can you give me some tips about figuring out what might be causing the issue. It’s something that is happening for a longer period now, I also tried using different kernels but usually using the zen kernel.
I usually look up the journalctl logs but coulnd’t find anything significant, like fatal errors etc. journalctl -b -1
It’s a Dell Vostro 5515 laptop, 32GB RAM, 16 core AMD Ryzen 7 5700U, AMD Radeon graphics.
NaN
12 September 2023 12:32
3
As SGS says garuda-inxi
please for evey help request,
please try this, the journey might be very frustrating but we will get there
Primary Diagnostic Steps.
Testing Alternate Kernels:
Changing kernels is one of the easiest diagnostic steps you can perform and it resolves far more issues than you’d ever expect. Whenever you start to experience unusual issues with your system, the first thing you should do is test at least three alternate kernels. For those experiencing severe system freezes/crashes testing out alternate kernels should always be your first step. Check your logs for any instances of kernel panic , as thi…
nik
12 September 2023 12:35
4
Hi, below is the link to the garuda-inxi garuda pastebin. Thanks will check out the link.
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=ba551cad-ce06-470f-8dfa-6c7c87bb7ec1 rw rootflags=subvol=@
quiet
cryptdevice=UUID=1b48f261-0d44-409b-bf81-01f8a36f7a37:luks-1b48f261-0d44-409b-bf81-01f8a36f7a37
root=/dev/mapper/luks-1b48f261-0d44-409b-bf81-01f8a36f7a37 quiet
resume=/dev/mapper/luks-85c9802f-e4b5-46f5-913a-2ba22e1a5e3d loglevel=3
Type: Laptop System: Dell product: Vostro 5515 v: 1.14.1
serial: <superuser required> Chassis: type: 10 v: 1.14.1
Mobo: Dell model: 0P3R55 v: A00 serial: <superuser required> UEFI: Dell
v: 1.14.1 date: 12/05/2022
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1455 high: 1800 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1486 4: 1397 5: 1397 6: 1397 7: 1400 8: 1397 9: 1640 10: 1400 11: 1587
12: 1400 13: 1800 14: 1400 15: 1400 16: 1400 bogomips: 57493
Device-1: AMD Lucienne vendor: Dell driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 50.0 C
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0c45:6a10
class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x152e built: 2020
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: AMD Radeon Graphics
(renoir LLVM 16.0.6 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 35.0 C
IF-ID-1: br-5af4c72c1cb2 state: down mac: <filter>
IF-ID-2: br-ae0117b27bdc state: down mac: <filter>
IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-4: vboxnet0 state: up speed: 10 Mbps duplex: full mac: <filter>
IF-ID-5: veth54ebe60 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth82a115f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethf646453 state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0cf3:e007
Local Storage: total: 1.49 TiB used: 242.92 GiB (15.9%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 31.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: KDI model: OM3PDP3-AD NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 10100002 temp: 34.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Generic model: SD MMC MS PRO
size: 116.36 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 897.44 GiB size: 897.44 GiB (100.00%)
used: 143.19 GiB (16.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1b48f261-0d44-409b-bf81-01f8a36f7a37
used: 2.1 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 897.44 GiB size: 897.44 GiB (100.00%)
ID-4: /var/log raw-size: 897.44 GiB size: 897.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.44 GiB size: 897.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.7 GiB used: 23 MiB (0.1%) priority: 100
ID-2: swap-2 type: partition size: 33.78 GiB used: 0 KiB (0.0%)
mapped: luks-85c9802f-e4b5-46f5-913a-2ba22e1a5e3d
System Temperatures: cpu: 45.0 C mobo: 38.0 C gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): cpu: 2923
Processes: 452 Uptime: 6h 1m wakeups: 20087 Memory: total: 32 GiB note: est.
available: 30.7 GiB used: 9.78 GiB (31.8%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1584
pm: pacman pkgs: 1578 libs: 384 tools: octopi,paru pm: flatpak pkgs: 6
inxi: 3.3.29
System install date: 2023-02-08
Last full system update: 2023-09-05
system
Closed
26 September 2023 12:36
5
