Best settings for comfortably playing PC VR games
Im japanese if not good english im sorry The best settings for comfortably playing PC VR games (VRChat, etc.) using Garuda Linux and Quest 3 (when I tried, there was severe lag and freezing)
I’m a Japanese who loves Garuda. I’m not good at explaining, but I’ll try my best. Garuda I want to play PC VR games on Linux. I was playing on Windows, but I don’t know if it was a Windows system, but it broke and stopped working. I tried to make a Windows live USB, but for some reason Windows ISO didn’t work, so I struggled for a few days, but I was tired so I gave up. I tried to play VR games (VR chat) on Garuda before, and tried various things, but I couldn’t play properly because of lags and freezes. I’m tired of Windows, so if anyone knows the best settings for steamVR or ALVR on Garuda (I tried ALVR before, but it didn’t work properly.) or other recommended tools, please let me know.
Long and pointless text I’m sorry that my explanation is poor and the text is difficult to understand.
╭─rodorin@rodorin in ~
╰─λ garuda-inxi
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ad0893a0-0028-46c6-a080-0e0301832ba9 rw rootflags=subvol=@
quiet resume=UUID=98d98b6c-348d-4c07-bdf1-241624d1da50 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Desktop System: ASRock product: B660 Pro RS v: N/A
Mobo: ASRock model: B660 Pro RS serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 19.01
date: 09/30/2024
Info: model: 12th Gen Intel Core i5-12600KF bits: 64 type: MST AMCP
microcode: 0x36
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 800 min/max: 800/4900:3600 scaling: driver: intel_pstate
bogomips: 117964
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: ASUSTeK
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-2,HDMI-A-1 empty: DP-1,HDMI-A-2,Unknown-2 bus-ID: 01:00.0
chip-ID: 10de:1e07 class-ID: 0300
d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-2 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
memory: 10.74 GiB display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2080 Ti driver: nvidia v: 565.57.01 device-ID: 10de:1e07
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.6-arch1.1 (LLVM 18.1.8)
Device-1: Intel Alder Lake-S HD Audio vendor: ASRock driver: snd_hda_intel
Device-2: NVIDIA TU102 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: Logitech G733 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-4.2:6 chip-ID: 046d:0ab5 class-ID: 0300
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1
lmp-v: 4 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 5.49 TiB used: 27.36 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 28.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A750 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 1T00
tech: SSD serial: <filter> fw-rev: 40RL scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R060 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD30EZRZ-00GXCB0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Silicon Power model: UFD 2.0 16G
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 896.92 GiB size: 896.92 GiB (100.00%)
used: 27.36 GiB (3.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 896.92 GiB size: 896.92 GiB (100.00%)
ID-4: /var/log raw-size: 896.92 GiB size: 896.92 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.92 GiB size: 896.92 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.3 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 28.0 C mobo: N/A
Memory: total: 32 GiB available: 31.18 GiB used: 5.76 GiB (18.5%)
Processes: 389 Power: uptime: 47m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 2071 libs: 596 tools: octopi,paru,yay
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-11-09
Last full system update: 2024-11-09
╭─rodorin@rodorin in ~ took 2s
╰─λ
Have you tried running in a x11 session not wayland
@Kenyuu please, keep the search query heading short and limited to the basic problem :slight_smile:
Everything else then in the post.
