So I've just resolved issues caused by grub-customizer and am back to garuda stock settings for grub. I now know that grub-customizer is not the way. What are some best practices for me to remove entries from the grub menu? Ideally I'l like to just have Garuda / Windows / Snapshots as options.
I've tried messing around with the scripts in /etc/grub.d but I almost always end up with a syntax error while generating the /boot/grub/grub.cfg file using update-grub. Do I just need to get better at modifying those scripts, or is there a single script I can make and run at the end to remove the entries I want?
I want to stay away from modifying /boot/grub/grub.cfg directly since I want my changes to persist past grub updates.
I never wanted to ask that but you make me.
WHY?
I see grub for 1-10 seconds, 10 when I select something from custom.cfg and the other DE's grub appears.
However, there is no M$ included
yes, it is now stock since I uninstalled grub-customizer, deleted all the configs then re-installed grub. I'll mess around with efibootmgr and probably kill my bootloader
thanks
@tbg Not exactly constructive, if you meant it as a joke then yes, haha. I agree grub-customizer messed up my boot menu. I have fixed that as of now and it is back to the way that it was when I freshly installed Garuda (at least visually). My question was about the best practices around modifying the default Garuda grub menu, since I now know grub-customizer was not a good option.
@petsam I'd like to remove Advanced options for Garuda and Memtest. Ideally just seeing Garuda / Windows / Snapshots
The things they want to remove are not there for fun, unfortunately they won't realize that until there is a problem.
If we help them to remove them, one day they will say: "But why didn't anyone tell me and even help me to remove it?
It's your system now, you are the admin, do what you can but don't lecture us about what our way is.
