I'm just wondering if I need to look at my graphics drivers and adjust anything?
Nothing is broken!
just wondering if anyone has any advice on how to maintain/configure graphics drivers? Best practices, do's and don't s, etc. Whatever documentation you suggest I read up on.
I guess these tips could apply to any piece of hardware on a computer.
Where should I look to find the proper drivers for specific hardware?
Here is my garuda-inxi. I'm assuming I'll need some information from here, most likely hardware identification.
mdoverl@mdoverl i
╰─λ garuda-inxi
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=35b1927f-308f-40c8-8e49-adf1b6d5ab3c rw rootflags=subvol=@
quiet
cryptdevice=UUID=2d2f6df3-908a-471a-bab8-ca7384cd7e1c:luks-2d2f6df3-908a-471a-bab8-ca7384cd7e1c
root=/dev/mapper/luks-2d2f6df3-908a-471a-bab8-ca7384cd7e1c quiet splash
resume=/dev/mapper/luks-e0141a34-b4b2-493b-88b1-893f9cda231a loglevel=3
Type: Desktop System: Dell product: XPS 8940 v: N/A
Mobo: Dell model: 0KV3RP v: A00 serial: <superuser required> UEFI: Dell
v: 2.10.0 date: 09/14/2022
Info: model: Intel Core i5-10400 bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3502 high: 4138 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 2900 2: 4093 3: 2900
4: 4138 5: 4100 6: 4100 7: 2900 8: 4103 9: 2900 10: 2900 11: 4100 12: 2900
bogomips: 69597
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc8 class-ID: 0300
Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Dell
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:21c4
Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1520x570mm (59.84x22.44")
s-diag: 1623mm (63.91")
Monitor-1: HDMI-1-0 pos: primary,right res: 3840x2160 hz: 30 dpi: 61
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.27") modes: N/A
Monitor-2: HDMI-2 pos: left res: 1920x1080 hz: 60 dpi: 70
size: 698x392mm (27.48x15.43") diag: 801mm (31.52") modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics 630 (CML
GT2) direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Device-1: Realtek vendor: Rivet Networks driver: r8168 v: 8.051.02-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:2600 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 11.38 TiB used: 29.53 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000AS0002-1NA17Z
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5980 serial: <filter> rev: AR15 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000LM024-2AN17V
type: HDD rpm: 5526 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Dell model: Recovery USB
size: 7.43 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
used: 29.53 GiB (6.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2d2f6df3-908a-471a-bab8-ca7384cd7e1c
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
ID-4: /var/log raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
ID-5: /var/tmp raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.21 GiB used: 1.8 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 25.53 GiB used: 0 KiB (0.0%)
mapped: luks-e0141a34-b4b2-493b-88b1-893f9cda231a
System Temperatures: cpu: 49.0 C pch: 47.0 C mobo: 48.0 C
Fan Speeds (RPM): cpu: 795 fan-2: 990
Processes: 370 Uptime: 3h 18m wakeups: 0 Memory: 23.21 GiB
used: 8.95 GiB (38.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 2112
libs: 574 tools: octopi,pamac,paru pm: appimage pkgs: 0 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-11-30
Last full system update: 2022-12-01
Is partially upgraded: Yes
