Best laptop for Garuda
I am using a MSI laptop and am planning to purchase a new one - please help me with something (these questions are specific to running Garuda only)
  1. Should I go for intel or AMD ?
  2. Garphics card ?
  3. Specs with which I get best performance (like hot knife on butter) ?
    Any specific laptop suggestion will be welcome.
    Can I also purchase a samsung curved monitor and use it with Garuda without any issues ?
Your choice.
Your choice.
The best specs you can afford.
Yes.
I’ve got 3 brands of curved monitors, no issues at all.
See
Most of the components work fine under Linux nowadays, but still, make sure to check this before purchasing hardware.
