Best Desktop for 2 in 1 Convertible?
Hello Everyone. I just got a Lenovo Thinkpad C13 Yoga Chromebook I’m converting to a “Dragonbook” and it folds to tablet mode. I just installed Mokka but is there a better DE that would give a better tablet experience? (That’s a trick question because everyone knows there’s no better desktop than mokka.) It also has an active stylus with pressure sensitivity. Here’s my specs:
garuda@garuda-mokka in ~ as 🧙
󰛓 ❯ garuda-inxi
Kernel: 6.16.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
misobasedir=garuda root=miso:LABEL=GARUDA_MOKKA_BROADWING quiet
systemd.show_status=1 checksum=y driver=free nouveau.modeset=1
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Laptop System: Google product: Morphius v: rev6
Mobo: Google model: Morphius v: rev6 serial: <superuser required>
part-nu: sku1510014992 UEFI: coreboot v: MrChromebox-2503.0 date: 04/27/2025
ID-1: BAT0 charge: 42.4 Wh (84%) condition: 50.5/51 Wh (99%) volts: 8.18
min: 7.7 model: LGC L19L4PG type: Li-ion serial: <filter> charging:
status: discharging control: start: N/A end: 100% cycles: 294
Device-1: hid-0018:27C6:0ED1.0001-battery model: GDIX0000:00 27C6:0ED1
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 7 3700C with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2300 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 36732
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 48.0 C
Device-2: Chicony EasyCamera 5M driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.1:4 chip-ID: 04f2:b639
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.2:5 chip-ID: 5986:212f
class-ID: 0e02
compositor: kwin_wayland driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x8544 built: 2019
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 10 Graphics
(radeonsi raven ACO DRM 3.64 6.16.5-zen1-1-zen) device-ID: 1002:15d8
memory: 500 MiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Vega 10 Graphics (RADV RAVEN) driver: mesa radv v: 25.2.2-arch1.1
device-ID: 1002:15d8 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.2-arch1.1 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
API: ALSA v: k6.16.5-zen1-1-zen status: kernel-api tools: N/A
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 8087:0029
Local Storage: total: 325.41 GiB used: 0 KiB (0.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SD64G
size: 58.27 GiB block-size: physical: 512 B logical: 512 B type: Removable
tech: SSD serial: <filter> scheme: GPT
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-256G-1001 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 11170101 temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: swap-1 type: zram size: 15.07 GiB used: 12.2 MiB (0.1%)
System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): fan-1: 3600
Memory: total: 16 GiB note: est. available: 15.07 GiB used: 3.56 GiB (23.6%)
Processes: 317 Power: uptime: 25m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 5.99 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1236 libs: 307 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2 running-in: konsole
inxi: 3.3.39
Garuda (2.8.2-2):
System install date:     2025-09-08
Last full system update: 2025-09-07
21/23 checks run in 2.15 seconds ⌛
Powered by garuda-health 🦅
--- CRITICAL ---
- No (intended) kernels are installed in /boot (fix available)
--- HIGH ---
- Snapper snapshots directory is missing (fix available)
--- LOW ---
- Failed systemd services found: snapper-cleanup.service
i say use a live isos with kde & gnome and see what you like on kde enable touch mode and go into widow decorations an make the buttons a size bigger.
tbh I think kde is better cause you can size the UI for human finger size but some like gnome so try out either. Though I personally would theme mokka a bit differently to fit in the scope of a touch screen.
I’ve never tried KDE in tablet mode so I’m not real sure what you mean by that, but I bet if I try it I may see what you mean.
Inside like where the mouse settings are there should be a options not much really changes other then gestures? An the UI should get a tiny bit bigger for kde apps. But everything can at least be made to fit your needs.
Maybe these videos might help!
Thank you both very much.
