Kernel: 6.9.12-x64v-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=30342c7e-f5f2-4539-b072-b8c3e5701d39 rw rootflags=subvol=@
Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: 1: GDM v: 46.2 note: stopped 2: SDDM
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4/ac serial: <filter>
uuid: 7059a1a8-f454-0000-0000-000000000000 UEFI: American Megatrends LLC.
v: P2.20 date: 02/24/2022
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3800 min/max: 2200/4850 boost: enabled
base/boost: 3800/4850 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121372
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 555.58.02 alternate: nvidiafb,nouveau,nvidia_drm
non-free: 550.xx+ status: current (as of 2024-06; EOL~2026-12-xx)
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 06:00.0
chip-ID: 10de:2482 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 0c45:8006 class-ID: 0301
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
Screen-1: 0 s-res: 3520x1159 s-dpi: 96 s-size: 931x307mm (36.65x12.09")
s-diag: 980mm (38.59")
Monitor-1: DP-0 pos: primary,top-left res: 1920x1080 dpi: 90
size: 543x302mm (21.38x11.89") diag: 621mm (24.46") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1600x900 hz: 60 dpi: 94
size: 432x240mm (17.01x9.45") diag: 494mm (19.46") modes: N/A
drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: gbm,wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 555.58.02 device-ID: 10de:2482
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.9.12-x64v-xanmod1-1 status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: n/a (root, process) with:
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.1:6 chip-ID: 0bda:8771
Device-2: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 8087:0aa7
Report: ID: hci1 rfk-id: 1 state: up address: <filter> bt-v: 4.2 lmp-v: 8
status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 4.55 TiB used: 2.46 TiB (54.2%)
model: WD10EZEX-00BBHA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 1.2 TiB size: 1.2 TiB (100.00%) used: 825.41 GiB (67.3%)
fs: btrfs block-size: 4096 B dev: /dev/sdb5 maj-min: 8:21
used: 28.1 MiB (29.2%) fs: vfat block-size: 512 B dev: /dev/sdb1
maj-min: 8:17
ID-3: /home raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
used: 825.41 GiB (67.3%) fs: btrfs block-size: 4096 B dev: /dev/sdb5
maj-min: 8:21
ID-4: /var/log raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
maj-min: 8:21
ID-5: /var/tmp raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
maj-min: 8:21
zswap: no
ID-1: swap-1 type: zram size: 31.27 GiB used: 2.24 GiB (7.2%)
System Temperatures: cpu: 51.1 C mobo: N/A gpu: nvidia temp: 59 C
Memory: total: 32 GiB available: 31.27 GiB used: 13.06 GiB (41.8%)
Processes: 519 Power: uptime: 4d 9h 28m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.45 GiB services: gsd-power,
Packages: 1952 pm: pacman pkgs: 1864 libs: 538
tools: octopi,pacseek,paru,trizen pm: flatpak pkgs: 88 Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.35
System install date: 2024-08-06
Last full system update: 2024-08-07 ↻
Windows dual boot: Yes
Failed units: logrotate.service pamac-cleancache.service
I tried looking this up and people were saying it might have something to do with certain GNOME extensions, so here’s my list of those:
- AATWS
- AppIndicator and KStatusNotifierItem Support
- ArcMenu
- Bluetooth Quick Connect
- ClipQR
- Custom Reboot
- Dash to Panel
- Emoji Copy
- Media Progress
- Mock tray
- Mount Meter
- Net speed Simplified
- Notification Counter
- OpenWeather Refined
- PiP on top
- ram_sens (what I am using to see the gradual memory usage increase over time)
- Run Android Emulators
- Screenshot Tool
- Tailscale Status
- Tiling Assistant
- TwitchLive Panel (disabled)
- Wifi QR Code
- Window Is Ready - Notification Remover
What are some commands/tools I can use to try to diagnose why this is happening?
