BeautyLine missing Kde Connect icon
Hi all. BeautyLine icon theme is missing icon for KdeConnect. Shows empty space in place of the icon in system tray. If I change icon theme, icon hows up.
Kernel: 6.17.6-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver3
root=UUID=a8526b5c-c454-4f55-a441-5b8b1313e978 rw rootflags=subvol=@
quiet resume=UUID=c1f666dc-6a4e-4a02-8303-f702bdfa07dd loglevel=3
mitigations=off sysrq_always_enabled=1
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Mini-pc System: Trigkey product: S5 v: N/A
Mobo: Trigkey model: S5 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 5800H508
date: 09/06/2024
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 50% rechargeable: yes status: discharging
microcode: 0xA500012
Speed (MHz): avg: 403 min/max: 403/3201 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 403 2: 403 3: 403
4: 403 5: 403 6: 403 7: 403 8: 403 9: 403 10: 403 11: 403 12: 403 13: 403
14: 403 15: 403 16: 403 bogomips: 102208
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 04:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 47.0 C
Device-2: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:28
chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
Monitor-1: HDMI-A-1 model: Sony TV serial: <filter> built: 2008 res:
mode: 1920x1080 hz: 60 scale: 140% (1.4) to: 1371x771 dpi: 30 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.6-arch1.1
renoir ACO DRM 3.64 6.17.6-arch1-1-znver3) device-ID: 1002:1638
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.6-arch1.1
device-ID: 1002:1638 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
Device-4: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.17.6-arch1-1-znver3 status: kernel-api tools: N/A
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
Local Storage: total: 2.3 TiB used: 1.08 TiB (46.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: Predator SSD GM7000 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.J.N2 temp: 50.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: PNY model: 480GB SATA SSD
tech: SSD serial: <filter> fw-rev: 5A0 scheme: GPT
ID-1: / raw-size: 1.85 TiB size: 1.85 TiB (100.00%) used: 1.08 TiB (58.1%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 668 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
used: 1.08 TiB (58.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 11.59 GiB used: 1.79 GiB (15.4%)
ID-2: swap-2 type: partition size: 13.84 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 47.0 C
Memory: total: 12 GiB available: 11.59 GiB used: 3.79 GiB (32.7%)
Processes: 419 Power: uptime: 8h 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.61 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1497 libs: 389 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2 running-in: konsole
inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2025-08-05
Garuda release:          250801
Last full system update: 2025-11-02
24/25 checks run in 0.84 seconds ⌛
Powered by garuda-health 🦅
Have you updated recently? There should be a fix for this.
thank you, have waited for months, posted on a day the fix is released, what are the odds.
