Hello.
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_DR460NIZED_HARPYEAGLE quiet systemd.show_status=1 driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0 serial: <filter> Chassis: type: 9
v: Mac-937CB26E2E02BB01 serial: <filter>
Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2 serial: <filter> UEFI: Apple
v: 428.40.10.0.0 date: 09/25/2021
Battery: ID-1: BAT0 charge: 20.9 Wh (43.1%) condition: 48.5/54.3 Wh (89.2%) volts: 7.4 min: 7.6
model: DP bq20z451 type: Li-ion serial: N/A status: Discharging cycles: 258
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A status: N/A
CPU: Info: Dual Core model: Intel Core i5-5250U bits: 64 type: MT MCP arch: Broadwell family: 6
model-id: 3D (61) stepping: 4 microcode: 2F cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12800
Speed: 1600 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 1600 2: 1610 3: 1600 4: 1668
Graphics: Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1626 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4") s-diag: 449mm (17.7")
Monitor-1: eDP1 res: 1440x900 hz: 60 dpi: 126 size: 290x180mm (11.4x7.1") diag: 341mm (13.4")
OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 02:00.0 chip-ID: 14e4:1570
class-ID: 0480
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
driver: bcma-pci-bridge v: N/A modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF-ID-1: enp0s20u2c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Bluetooth: Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8 bus-ID: 1-3.3:8
chip-ID: 05ac:828f class-ID: fe01
Drives: Local Storage: total: 127.91 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0128G size: 113 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: SA0Q
ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Switch size: 14.91 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.26 scheme: MBR
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 70.0 C mobo: N/A
Info: Processes: 195 Uptime: 28m wakeups: 7 Memory: 7.67 GiB used: 3.95 GiB (51.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1171 lib: 287
Hi, i am trying to install garuda linux on my macbook air 2015, it has a broadcom wifi chip and i need help in enabling wifi, i am still currently running it off the usb stick and not installed on my ssd, on other distro like linux mint there was an option to enable the proprietary driver for bcml
