I tried setting threshold in nix using executables and tlp but that always ended in random controllers error like usb for camera, night light etc etc. so switched back to Garuda-arch but not found lxqt-kwin like battery watcher in gnome.
Here is my garuda-inxi:
╰─λ garuda-inxi
root=UUID=2ed2acf4-12e7-497f-8e9e-ffd85e2b465f rw rootflags=subvol=@
quiet resume=UUID=2f3ba04a-a237-4756-a5f2-6aab596e0917 loglevel=3 ibt=off
Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412DA_X412DA
Mobo: ASUSTeK model: X412DA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X412DA.316 date: 10/08/2021
ID-1: BAT0 charge: 13.1 Wh (50.2%) condition: 26.1/37.1 Wh (70.4%)
power: 4.4 W volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 432
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1443 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
3: 1397 4: 1223 5: 1400 6: 1400 7: 1228 8: 2100 bogomips: 33537
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 35.0 C
Device-2: IMC Networks [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1:3 chip-ID: 13d3:56dd
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x07f6 built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.2:4
chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 476.94 GiB used: 3.67 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3512GJ3 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: E8FK1A.2 temp: 26.9 C scheme: GPT
used: 3.67 GiB (0.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 5.73 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (rpm): cpu: 1900
Processes: 283 Uptime: 20m wakeups: 1 Memory: total: 6 GiB
available: 5.73 GiB used: 2.56 GiB (44.6%) Init: systemd v: 254
pm: pacman pkgs: 1094 libs: 364 tools: paru Shell: fish v: 3.6.1
running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-11-17
Last full system update: 2023-11-17
