Hello, last time I noticed that my Huawei Matebook stop charging. It shows charging state even if I plug it off.
Kernel: 6.12.18-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 rw rootflags=subvol=@
resume=UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 loglevel=3 ibt=off
Desktop: GNOME v: 47.5 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1300
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1300 serial: <superuser required>
part-nu: C178 uuid: <superuser required> UEFI: HUAWEI v: 1.06
date: 09/14/2020
ID-1: BAT0 charge: 10.0 Wh (19.9%) condition: 50.3/54.9 Wh (91.5%)
volts: 7.5 min: 7.6 model: SUNWODA HB4593R1ECW-22S0 type: Li-ion
serial: <filter> status: charging cycles: 619
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
bogomips: 71881
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Huaqin driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 33.0 C
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:5451
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0893 built: 2019 res: 2160x1440
dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76") diag: 356mm (14")
ratio: 3:2 modes: max: 2160x1440 min: 640x480
API: Vulkan v: 1.4.304 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
Info: Tools: api: vulkaninfo wl: wdisplays x11: xdpyinfo, xprop, xrandr
Audio vendor: Huaqin driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Huaqin driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
vendor: Huaqin driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.18-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.0 status: active with: 1: pipewire-pulse
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 1358:c123
Local Storage: total: 476.94 GiB used: 207.53 GiB (43.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1027 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21117000 temp: 36.9 C scheme: GPT
used: 207.53 GiB (44.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 7.13 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (rpm): fan-1: 2767 fan-2: 3218
Memory: total: 8 GiB note: est. available: 7.13 GiB used: 3.11 GiB (43.6%)
Processes: 372 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.81 GiB services: gsd-power,
Packages: 1899 pm: pacman pkgs: 1854 libs: 464
tools: gnome-software,pamac,paru pm: flatpak pkgs: 45 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: terminology
inxi: 3.3.37
System install date: 2022-04-09
Last full system update: 2025-03-13
Failed units: syncthing@przemyslaw.service
upower -i /org/freedesktop/UPower/devices/battery_BAT0
native-path: BAT0
vendor: SUNWODA
model: HB4593R1ECW-22S0
serial: 12657
power supply: yes
updated: czw, 13 mar 2025, 11:14:03 (4 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: charging
warning-level: none
energy: 10,0542 Wh
energy-empty: 0 Wh
energy-full: 50,5539 Wh
energy-full-design: 55,2372 Wh
energy-rate: 0 W
voltage: 7,498 V
charge-cycles: 619
percentage: 19%
capacity: 91,5214%
technology: lithium-ion
charge-start-threshold: 75%
charge-end-threshold: 80%
charge-threshold-supported: yes
icon-name: 'battery-caution-charging-symbolic'
I try linux-zen and lts.
I have problems with that battery from begginning on every linux distro I try (it was charging all the time but I have to reboot or plug off and on cable) but from two days it donβt charge at all. Is it some driver issue? How to check?
Regards.
