Hi
My Removable battery is Recognized by the system but shows as an empty battery icon in the top bar. It is shown in inxi:
root=UUID=b6f3bfb4-b9ed-496b-944b-06e4c2a778e0 rw rootflags=subvol=@
Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.5 info: cairo-dock, lxqt-panel
Type: Laptop System: Hewlett-Packard product: HP 15 Notebook PC
v: 0973110002405F00000620180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 8015 v: 11.15 serial: <superuser required>
UEFI: American Megatrends v: F.21 date: 09/25/2014
ID-1: BAT0 charge: 0 Wh (0.0%) condition: 13.9/13.9 Wh (100.0%) volts: 10.7
min: 11.1 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: N/A cycles: 124
Info: model: AMD A8-6410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1119 high: 1216 min/max: 1000/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1076 2: 1048
3: 1139 4: 1216 bogomips: 15970
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: GCN 2
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Webcam type: USB
driver: uvcvideo bus-ID: 2-1.2:3 chip-ID: 05c8:0226 class-ID: 0e02
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x046a built: 2014
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-1: Realtek RTL8188EE Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8188ee v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8179
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
Local Storage: total: 698.64 GiB used: 24.9 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD075
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
ID-1: / raw-size: 698.34 GiB size: 698.34 GiB (100.00%)
used: 24.9 GiB (3.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 698.34 GiB size: 698.34 GiB (100.00%)
ID-4: /var/log raw-size: 698.34 GiB size: 698.34 GiB (100.00%)
ID-5: /var/tmp raw-size: 698.34 GiB size: 698.34 GiB (100.00%)
ID-1: swap-1 type: zram size: 10.64 GiB used: 23 MiB (0.2%) priority: 100
System Temperatures: cpu: 52.4 C mobo: N/A gpu: radeon temp: 52.0 C
Processes: 211 Uptime: 59m wakeups: 2 Memory: 10.64 GiB
used: 1.87 GiB (17.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1195 lib: 332
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.19
Garuda (2.5.8-1):
System install date: 2022-04-06
Last full system update: 2022-06-25 ↻
Windows dual boot: no
When i pull out the charging cable my laptop crashes. I sometimes get a "battery very low" warning on boot. It worked until some months ago (didn't bother with it because it the last (and slowest) of 3 laptops we have).
thanks in advance
