Hi garuda team,
Is there any software which shows how much time spend on battery when it is unplugged , (similar to some kind of windows which shows time speed on battery after last charge.)?
if yes, pls tell the name of that app?
Hi garuda team,
Yes.
Hi team,
I am not able to reply on thread that i created recently on topic battery manager software .
so i writing this again
if yes, pls tell the name of that app also ?
sry for this @BluishHumility
Kernel: 6.1.7-AMD arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd
root=UUID=00cfa451-7712-4386-97d6-273f1e6482ac rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
Mobo: HP model: 88DD v: 96.33 serial: <superuser required> UEFI: AMI
v: F.23 date: 10/20/2022
ID-1: BAT0 charge: 32.7 Wh (79.6%) condition: 41.1/41.1 Wh (100.0%)
volts: 11.7 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2104 high: 4052 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200
3: 3902 4: 4052 5: 2114 6: 1200 7: 2418 8: 2987 9: 2575 10: 1200 11: 1200
12: 1200 bogomips: 79082
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nvidia v: 525.85.05
alternate: nvidia_drm non-free: 525.xx+ status: current (as of 2022-12)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 42.0 C
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:0035 class-ID: fe01
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0058 built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.7-AMD) direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.1.7-AMD running: yes
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: N/A modules: rtw_8852ae
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
chip-ID: 10ec:8852 class-ID: 0280
bus-ID: 1-4:2 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 13.91 GiB (2.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: PC711 HFS512GDE9X073N size: 476.94 GiB block-size: physical: 512 B
rev: HPS0 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 200.5 GiB size: 200.5 GiB (100.00%) used: 13.82 GiB (6.9%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 89.8 MiB (35.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 200.5 GiB size: 200.5 GiB (100.00%)
used: 13.82 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 200.5 GiB size: 200.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 200.5 GiB size: 200.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.12 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.8 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 323 Uptime: 4m wakeups: 1 Memory: 7.13 GiB used: 3.64 GiB (51.0%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1442 libs: 388
tools: gnome-software,octopi,pamac,paru,yay Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-24
Last full system update: 2023-01-26
Failed units: systemd-vconsole-setup.service```
The thread was added to 4xx because, as usual, you have not included the information required for opening a help request. After you edit the post to include your garuda-inxi
and make an effort to describe what you have tried so far and what happened, we can open it back up for you.
Please, we shouldn't have to nag you to include the basic information on every post.
Try the "Battery and Brightness" widget.
It should show battery time remaining when you hover over the icon in the taskbar.
thank you for this but i know this .
I have different concern .
i want to show some gui or any other which show how many time u spend on battery something to similar to windows
Maybe ibam
? AUR (en) - ibam
Info here: https://ibam.sourceforge.net/
You might be able to -plot
it the way you want.
Sorry that I can not test it for you as I do not have a laptop.
To install it open up Konsole and type:
paru -S ibam
enter "Y" to review. Then hit "Q" to exit the review. Then "Y" to install.
After it is installed you should be able to look at a simple graph with typing ibam -plot
into Konsole. Additional commands can be seen by looking at the help for ibam
from putting ibam -h
into Konsole.
