Hello!
Background: I acquired a new Lenovo laptop around 3 months ago. I first had arch linux installed and my battery life was lasting around 3-4 hours per full charge. A few weeks ago, my battery life started to drain extremely fast. I decided to switch over to garuda linux (wayfire) after being introduced to it by a friend. After installation, the battery contained to drain fast. My friend and I decided to let the laptop fully discharge and recharge because we thought it might have been a detection problem. After fully recharging, the laptop was back to normal (it was not discharging from 100%-0% in 10-20 mins). Auto-cpufreq is also installed on the laptop. I did a systems update using yay before making this post. I have been using my laptop mainly to access the web (firedragon and librewolf tabs are what I have open majority of the time).
The rapid discharge issue is back again and I am unsure of what to do! I have a suspicious from looking at the battery section of the system specs that it has something to do with the condition of the battery being 17.5/57.0 (4 days ago it was at 52.1/57; found this on my old post on firedragon). Is there a reason that my fairly new laptop has this condition? If so, is there a way to fix it?
Please help!
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=283dfbce-87cb-4447-a29e-1b934e80d358 rw rootflags=subvol=@ quiet quiet
Desktop: wayfire v: 0.7.5 info: waybar vt: 1 dm: greetd Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 21F60029US v: ThinkPad T14s Gen 4
Mobo: LENOVO model: 21F60029US v: SDK0T76463 WIN serial: <superuser required> UEFI: LENOVO
v: N3PET13W (1.04 ) date: 03/29/2023
ID-1: BAT0 charge: 17.4 Wh (99.4%) condition: 17.5/57.0 Wh (30.6%) power: 20.0 W volts: 15.1
min: 15.4 model: Sunwoda 5B10W51876 type: Li-poly serial: <filter> status: charging cycles: 74
Info: model: 13th Gen Intel Core i7-1355U bits: 64 type: MST AMCP arch: Raptor Lake level: v3
note: check built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 3
microcode: 0x4119
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled cache: L1: 928 KiB
desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2200 high: 2600 min/max: 400/5000:3700 scaling: driver: intel_pstate
governor: performance cores: 1: 943 2: 2600 3: 1066 4: 994 5: 2600 6: 2600 7: 2600 8: 2600
9: 2600 10: 2600 11: 2600 12: 2600 bogomips: 62668
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915 v: kernel
arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:a7a1 class-ID: 0300
Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 30c9:00ad class-ID: fe01
Display: wayland server: Xwayland v: 23.2.0 compositor: wayfire v: 0.7.5 driver: gpu: i915
display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0xf99b built: 2021 res: 1920x1200 dpi: 162 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: Mesa Intel Graphics (RPL-U) direct-render: Yes
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:51f1 class-ID: 0280
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 953.87 GiB used: 33.35 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo model: UMIS RPETJ1T24MKP2QDQ size: 953.87 GiB
fw-rev: 1.2Q06A0 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 33.35 GiB (3.5%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 2
59:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 33.35 GiB (3.5%) fs: btrfs
ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 33.35 GiB (3.5%) fs: btrfs
ID-5: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 33.35 GiB (3.5%) fs: btrfs
ID-1: swap-1 type: zram size: 15.29 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 343 Uptime: 25m wakeups: 36591 Memory: total: 16 GiB note: est. available: 15.29 GiB
used: 5.01 GiB (32.8%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1345 libs: 402 tools: pamac,paru Client: shell wrapper
v: 5.1.16-release inxi: 3.3.29
System install date: 2023-09-03
Last full system update: 2023-09-09
