Hello there,
I am having a very bad battery life using garuda on my Thinkpad T14 (gen 1).
I am looking at the overview of powertop and I am having 3100 wakeups per second!! And a discharge reate of ~10 W.
I have tlp configured and everything should work fine without AC but I am getting a max of 3 hours usage with a 90% charge...
Is there a way to fix this ?
garuda-inxi's output :
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0c9822eb-18ec-4e24-9d9b-7685031e8127 rw rootflags=subvol=@
amd_iommu=on iommu=pt quiet splash rd.udev.log_priority=3
Desktop: i3 v: 4.16.1-191-gb521c18c info: i3bar vt: 7 dm: LightDM
v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20UDCTO1WW v: ThinkPad T14 Gen 1
Mobo: LENOVO model: 20UDCTO1WW v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: R1BET71W(1.40 )
date: 04/05/2022
ID-1: BAT0 charge: 42.9 Wh (83.3%) condition: 51.5/50.5 Wh (101.9%)
volts: 12.4 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: discharging cycles: 278
Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1398 min/max: 1400/1700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1395
3: 1397 4: 1397 5: 1397 6: 1396 7: 1397 8: 1393 9: 1396 10: 1397 11: 1397
12: 1396 13: 1397 14: 1397 15: 1398 16: 1397 bogomips: 54301
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 off: eDP-1 empty: DP-1,DP-2 bus-ID: 07:00.0
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 04f2:b6d0 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: Picom v: git-cd505
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 675x380mm (26.57x14.96")
s-diag: 775mm (30.5")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: Samsung LC27G5xT
serial: <filter> built: 2021 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled pos: primary
model: AU Optronics 0x573d built: 2018 res: 2560x1440 dpi: 158 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
class-ID: 0480
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.1 running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 2000 bus-ID: 05:00.0
IF-ID-1: br10 state: down mac: <filter>
IF-ID-3: virbr1 state: down mac: <filter>
IF-ID-4: virbr2 state: down mac: <filter>
bus-ID: 6-4:4 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address: <filter>
Local Storage: total: 1.05 TiB used: 172.97 GiB (16.1%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: ED2S5 size: 119.38 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS001TD9TNI-L2B0B size: 953.87 GiB block-size: physical: 512 B
rev: 11720C10 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 293.57 GiB size: 293.57 GiB (100.00%)
used: 153.41 GiB (52.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 32.1 MiB (12.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 293.57 GiB size: 293.57 GiB (100.00%)
ID-4: /var/log raw-size: 293.57 GiB size: 293.57 GiB (100.00%)
ID-5: /var/tmp raw-size: 293.57 GiB size: 293.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): fan-1: 2900 fan-2: 2900
Processes: 450 Uptime: 1d 5h 18m wakeups: 13 Memory: 30.58 GiB
used: 10.67 GiB (34.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1736
pacman: 1715 lib: 394 flatpak: 17 snap: 4 Shell: Zsh v: 5.9
running-in: kitty inxi: 3.3.19
e[1;34mGaruda (2.6.4-2):e[0m
e[1;34m System install date:e[0m 2021-12-14
e[1;34m Last full system update:e[0m 2022-07-12 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m tlp NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m samba.service vboxautostart-service.service vboxballoonctrl-service.service vboxdrv.service vboxweb-service.service
