.bashrc $PATH not updaing for nvm installation
I’ve tried to install nvm via nvm.sh, but nvm continues to not get added to $PATH:
which: no nvm in (/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr
/bin/vendor_perl:/usr/bin/core_perl)
Using the default fish terminal emulator, how can I proceed to install nvm in Garuda linux?
Kernel: 6.3.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b0aff0a6-c230-4053-b43e-55214acd87fb rw rootflags=subvol=@
resume=UUID=c521b8b7-0aed-4d7d-b959-564847a6d85d loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3401
date: 01/25/2017
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2221 high: 2364 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2200 2: 2364 3: 2205
4: 2284 5: 2281 6: 2346 7: 2000 8: 2091 bogomips: 67200
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
active: DP-1,DP-2,HDMI-A-1 empty: HDMI-A-2 bus-ID: 03:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8.2.4.3:10
chip-ID: 045e:0779 class-ID: 0102
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
gpu: amdgpu d-rect: 5560x4440 display-ID: 0
Monitor-1: DP-1 pos: middle-c res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: primary,top-left res: 1080x1920 size: N/A
modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.52 6.3.6-zen1-1-zen) direct-render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.3.6-zen1-1-zen status: kernel-api with: aoss
Local Storage: total: 10.46 TiB used: 9.75 TiB (93.2%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP480G4
tech: SSD serial: <filter> fw-rev: 0420 scheme: GPT
model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3000DM001-1CH166
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC29 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST4000DX001-1CE168
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC44 scheme: GPT
ID-1: / raw-size: 412.42 GiB size: 412.42 GiB (100.00%)
used: 31.4 GiB (7.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 412.42 GiB size: 412.42 GiB (100.00%)
ID-4: /var/log raw-size: 412.42 GiB size: 412.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 412.42 GiB size: 412.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 188 MiB (0.6%) priority: 100
ID-2: swap-2 type: partition size: 34.41 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 60.0 C
mem: 56.0 C
Processes: 291 Uptime: 16m wakeups: 0 Memory: available: 31.29 GiB
used: 5.55 GiB (17.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1840
libs: 548 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-05-24
Last full system update: 2023-06-09 ↻
You can add to a Fish path like so:
https://fishshell.com/docs/current/cmds/fish_add_path.html
NVM doesn't support fish. If you had read the project's readme on github they explain the reason for not being able to do that and provided alternatives to use in fish.
Though that doesn't mean you can't use nvm. If you have looked in your ~/.bashrc you would have noticed that nvm added it's path at the end of file. You can simply type
bash
In terminal to use bash and then nvm commands.
