Kernel: 5.14.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=47992a6e-0e9b-46f3-b596-cb6244652d89 rw
rootflags=subvol=@ loglevel=3 quiet
Desktop: LXQt 0.17.1 tk: Qt 5.15.2 info: cairo-dock, lxqt-panel
Type: Desktop Mobo: ASRock model: 980DE3/U3S3 serial: <filter>
BIOS: American Megatrends v: P2.00 date: 09/04/2015
Info: Quad Core model: AMD FX-4300 bits: 64 type: MCP
arch: Bulldozer family: 15 (21) model-id: 2 stepping: 0
microcode: 6000852 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 30458
Speed: 3807 MHz min/max: N/A Core speeds (MHz): 1: 3807 2: 3807
3: 3807 4: 3904
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB:
conditional, STIBP: disabled, RSB filling
vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon
Screen-1: 0 s-res: 3200x1080 s-dpi: 96
s-size: 846x285mm (33.3x11.2") s-diag: 893mm (35.1")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Monitor-2: DVI-D-0 res: 1280x1024 hz: 75 dpi: 96
size: 340x270mm (13.4x10.6") diag: 434mm (17.1")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.42.0
5.14.11-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 /
570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Ensoniq ES1371/ES1373 / Creative Labs CT2518
driver: snd_ens1371 v: kernel bus-ID: 05:05.0 chip-ID: 1274:1371
class-ID: 0401
Sound Server-1: ALSA v: k5.14.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: ASRock driver: r8169 v: kernel port: d800 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Integrated System Solution KY-BT100 Bluetooth Adapter
type: USB driver: btusb v: 0.8 bus-ID: 6-1:2 chip-ID: 1131:1001
class-ID: fe01
address: <filter>
Local Storage: total: 4.78 TiB used: 4.16 TiB (87.1%)
model: WD10EZRZ-22HTKB0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate
model: ST1000DM003-1SB10C size: 931.51 GiB block-size:
rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: N/A
serial: <filter> rev: 1A01 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Mushkin model: MKNSSDTR240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 6A scheme: MBR
ID-5: /dev/sdg maj-min: 8:96 vendor: Seagate
model: ST2000DM008-2FR102 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: <unknown> type: HDD
rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-6: /dev/sdh maj-min: 8:112 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 14.54 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported
enclosure?
ID-1: / raw-size: 38.06 GiB size: 38.06 GiB (100.00%)
used: 11.36 GiB (29.8%) fs: btrfs dev: /dev/sdd6 maj-min: 8:54
ID-2: /home raw-size: 462.29 GiB size: 454.91 GiB (98.40%)
used: 347.9 GiB (76.5%) fs: ext4 dev: /dev/sdc5 maj-min: 8:37
ID-3: /var/log raw-size: 38.06 GiB size: 38.06 GiB (100.00%)
ID-4: /var/tmp raw-size: 38.06 GiB size: 38.06 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.67 GiB used: 2 MiB (0.0%)
System Temperatures: cpu: 26.1 C mobo: N/A gpu: amdgpu
temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1477
Processes: 263 Uptime: 1h 43m wakeups: 0 Memory: 11.67 GiB
used: 2.56 GiB (21.9%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1472
lib: 437 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.06
From what I found by searching some relative topics, garuda use bash as default shell and fish. In my user's directory I have .bashrc, .bashrc_garuda and .zshrc. From my understanding .zshrc is there in case someone change the shell to zsh and isn't used by default, also .bashrc(which has only some basic confg) doesn't used and replaced by .bashrc_garuda on login to lxqt because of the relative autostart command.
I have some questions about bashrc though.
- Can I edit the .bashrc_garuda to add some stuff there or is somehow autogenerated?
- There is an alias command there with name "helpme" which outputs "command not found" when I try to run it. Do I need to install an extra package?
- I also have .bash_history file which have some commands I used previously, but they don't appear it alacritty and when run some other only. I suppose there is a history from fish, but I'm pretty sure I could access them before, and also I couldn't find a history file in .config/fish directory so where this other commands stored. I haven't touch any of those files or change anything relative to terminal, except alacritty's config to change the font size.
