Hello everyone,
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=14c396d6-5048-45b2-903b-042f341ab1a3 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: U36JC v: 1.0
Mobo: ASUSTeK model: U36JC v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: U36JC.205 date: 01/26/2011
Info: model: Intel Core i5 M 480 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1604 high: 1740 min/max: 1199/2667 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1625 2: 1445
3: 1609 4: 1740 bogomips: 21280
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT218M [GeForce 310M] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0a70 class-ID: 0300
Device-3: Chicony Asus Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:4 chip-ID: 04f2:b1b9 class-ID: 0e02
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 120
size: 290x160mm (11.4x6.3") diag: 331mm (13")
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel
bus-ID: 03:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wls1 state: up mac: <filter>
vendor: ASUSTeK U6V/U31J laptop driver: r8169 v: kernel port: 8000
bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: ens5 state: down mac: <filter>
Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:5 chip-ID: 0cf3:3005 class-ID: e001
Local Storage: total: 232.89 GiB used: 12.02 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 Series
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 9B0Q scheme: MBR
ID-1: / raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
used: 12.02 GiB (16.4%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-2: /home raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
ID-3: /var/log raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Processes: 230 Uptime: 5m wakeups: 1 Memory: 7.55 GiB used: 1.8 GiB (23.8%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0
Packages: pacman: 1440 lib: 403 Shell: fish v: 3.3.1 default: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.11
I have been doing a bit of research but did not find much info about the fish prompt.
I did know bash but not fish. It seems to add some interesting features.
However, even if I really like the current version prompt, where can I find the info about the fields? For example the lambda symbol, the fact a cross shows when a shell function returned an error etc?
╭─erics@U36JC in ~ took 2s
╰─λ
I really would like to know a bit more about those.
And I apologise if I did not search well or did not find it.
Thanks again for the great distro, and nice forum here, and all, have a nice day.
Eric
