Bang and Olufsen speakers with Garuda
Hello, I am very new to Garuda and put the XDE dr4g0n1zed in my laptop almost 2 weeks ago. I got everything set up by looking through much of the advise posted on here but one thing I can’t seem to get to the bottom of is with my speakers currently. I remember seeing somewhere that Bang and Olufsen isn’t supported on Linux so perhaps I’m lucky I even have sound at all but it just sounds a little thin and I have to turn it up much louder than I used to for easy listening. I do have easy effects which helps a little but I guess there’s only so much one can do with less speakers I guess. Otherwise I do love the set up and managed to work out other issues and wonder why I never made the switch to Linux years ago (:
My laptop is an HP laptop 17-ce1xxx my processers are 8 x Intel Coree i7-10510U CPU 1.80GHz, got 16GB of RAM, I do have ndvia graphic card but my about page currently says “mesa intel UHD graphics”.
Hopefully this information is helpful with getting to my solution as I haven’t used a forum in years (:
Welcome to the forum
Please provide your
as per the forum template
Search in forum for JamesDSP
Download
Maybe it helps a little.
I hope i do this right
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a51d7358-30f2-47c4-a552-9712de5eb9d7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
wm: kwin_wayland tools: avail: lxlock vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: HP product: HP ENVY Laptop 17-ce1xxx
Mobo: HP model: 86B0 v: 84.16 serial: <superuser required>
part-nu: 6UX02AV uuid: <superuser required> UEFI: Insyde v: F.07
date: 08/06/2020
ID-1: BAT0 charge: 36.9 Wh (84.6%) condition: 43.6/43.6 Wh (100.0%)
volts: 13.1 min: 11.6 model: 333-1B-35-A LK03052XL type: Li-ion
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xFC
Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
8: 800 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d13
class-ID: 0302
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.7-arch1.1
device-ID: 8086:9b41 memory: 7.48 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.2.7-arch1.1
device-ID: 8086:9b41 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce MX250 driver: nvidia v: 565.57.01
device-ID: 10de:1d13 surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.2.7-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 104.02 GiB (10.9%)
model: MZVLQ1T0HALB-000H1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS2NFXV temp: 25.9 C scheme: GPT
used: 104.02 GiB (10.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.32 GiB used: 51.2 MiB (0.3%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 56.0 C pch: 51.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 5.27 GiB (34.4%)
Processes: 332 Power: uptime: 8h 9m states: freeze,mem,disk
suspend: s2idle wakeups: 7 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
Packages: 1640 pm: pacman pkgs: 1636 libs: 459 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 4 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-11-19
Last full system update: 2024-11-27 ↻
I will try JamesDSP and potentially dump easyeffects
edits: I tried JamesDSP and it crashed ): I made sure to get the regular one and not pulse audio version
edit #2 I deleted easy effects and restarted then ran JamesDSP and now my sound is really coming through !!
edits again: though … the sound is still controlled from the main line so I have to have the main one turned up and then the jamesDSP goes on top of it. Wow my sound is weird, I basically have to tweak around with the sound settings because it seems I have 4 listings on that currently. Comet Lake PCH-LP cAVS speaker has some duplicates but there’s not much I can do about that. The others are Coment Lake PCH-LP cAVS HDMI display ports 1, 2 and 3 output but I guess that’s the HDMI. So much confusion but JamesDSP is better than easyeffects so far
Edits again for more context but it’s another reply because it wouldn’t let me edit a 4th time I guess: To put into perspective the issues I have with my sound after dumping windows for Linux is that before I used to run my sound at 20% and that was loud enough for me in a small room. If I wanted to turn it up in said small room I could turn it to 40% or 50% but would be content with 40% in a small room. In a bigger room I could do 70% and get a pretty substantial output and for that I’ve never had to turn my sound all the way to 100%.
Now with my current set up I have to turn my speakers to 50% just to have a low comfortable volume and basically have to turn it almost to max or 80% or 90% and even then it still sounds a bit thin like there’s less speakers or lower quality or if it was coming from a cave or if you used to record audio on a cell phone back then. Which speaking of cell phone my current phone which is an LG G8 is actually louder than my computer which is quite unfortunate.
Also I noticed that every so periodically JamesDSP will crash and then I won’t have sound so that’s not great … ): I meant to post this on the post that was deleted but then when I edited the post before what I said showed on there so I guess this is a triple post of sorts which was unintended but hopefully not a problem :melting_face:
