When adding my own script it did not load even with it being chmod +x
With the default setup.sh I had to chmod +x then add what I wanted inside.
Please update the Autostart to work with other .sh file after adding them for start up.
Thank you.
Thank you.
Well, I had the same problem, but with older edition.
It wasn't solved, but I made a .desktop file and it worked fine.
With my installation (26 Nov - garuda-dr460nized r51.0ea2203-1), autostart-scripts/setup.sh was not executable, while autostart/*.desktop were executable.
The .desktop files should not be executable. They also fill journal with cosmetic errors about it.
Now I realize why the setup script never self-deleted (as is the content code)
I did not get the .desktop working but I got the script working by adding the #!/bin/sh in the first line.
On xfce desktop it worked without that line.
