I'm trying to get my laptop to do this :
if (sharepoint "network_A" is detected):
connect to "network_A"
elif (wifi "network_B" is detected):
connect to "network_B"
sharepoint = network_A
wifi = network_B
I tried this :
- Settings > Connection > network_A > General configuration > Connect automatically with priority > 2
- Settings > Connection > network_B > General configuration > Connect automatically with priority > 1
But this does not force disconnection from network_B when network_A is detected.
garuda-inxi output :
Kernel: 5.18.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=394702fa-734d-4ffe-be2e-fc60fa05f197 rw rootflags=subvol=@
resume=UUID=6e50783f-d483-49d4-ae7f-6d21a4cb652d loglevel=3
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop M3401QA_M3401QA
Mobo: ASUSTeK model: M3401QA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: M3401QA.303 date: 08/06/2021
ID-1: BAT0 charge: 60.5 Wh (100.0%) condition: 60.5/63.0 Wh (96.0%)
volts: 12.0 min: 12.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 3
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3209 high: 4203 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2332 2: 2518
3: 3697 4: 3930 5: 3960 6: 4203 7: 3632 8: 3345 9: 3316 10: 2768 11: 3679
12: 3021 13: 1915 14: 3777 15: 2532 16: 2725 bogomips: 102206
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3
active: HDMI-A-1,eDP-1 empty: none bus-ID: 03:00.0 chip-ID: 1002:1638
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 13d3:5458 class-ID: fe01 serial: <filter>
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1015x317mm (39.96x12.48")
s-diag: 1063mm (41.86")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: HP Z24n G2
serial: <filter> built: 2019 res: 1920x1200 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: Samsung 0x4154
built: 2020 res: 1920x1200 hz: 90 dpi: 161 gamma: 1.2
size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10 modes:
max: 2880x1800 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.2-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Device-4: Razer USA Kraken Tournament Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 1532:0520
Sound Server-1: ALSA v: k5.18.2-zen1-1-zen running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-2:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 953.87 GiB used: 54.21 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZ
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 002C
temp: 31.9 C scheme: GPT
ID-1: / raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
used: 54.21 GiB (5.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
ID-4: /var/log raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.1 GiB used: 1.34 GiB (8.9%)
ID-2: swap-2 type: partition size: 16.61 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 66.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): cpu: 3200
Processes: 431 Uptime: 18h 17m wakeups: 95 Memory: 15.1 GiB
used: 9.78 GiB (64.8%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1716 lib: 356 Shell: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-01-04
Last full system update: 2022-06-09 ↻
Failed units: fonthelper.service
Hope someone knows how to do this
