Autologin xfce
Hello Everyone, I have searched the forum regarding this and could not find a way to get autologin to work , even edited the /etc/lightdm/lightdm.conf file as mentioned on other sites. Is it possible to autologin. Please assist.
Thank you.
Hello @Hannes, to receive help here, you must first post the result of your ā€˜garuda-inxi’ command, we need some information.
  Kernel: 6.16.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=01923acb-d818-481c-8528-5855e677c28e rw rootflags=subvol=@
    quiet loglevel=3
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Dell product: OptiPlex 7020 v: 00
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: Dell model: 0F5C5X v: A00 serial: <superuser required> part-nu: 05A5
    uuid: <superuser required> BIOS: Dell v: A18 date: 05/30/2019
  Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1178 min/max: 800/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1178 2: 1178 3: 1178 4: 1178 bogomips: 26339
  Device-1: NVIDIA GT218 [GeForce 210] vendor: ASUSTeK driver: nouveau
    v: kernel non-free: series: 340.xx status: legacy (EOL~2019-12-xx) last:
    release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
    built: 2006-2013 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
    active: HDMI-A-1 empty: DVI-I-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0a65
    class-ID: 0300 temp: 51.0 C
  Display: x11 server: X.Org v: 21.1.18 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
    dri: nouveau gpu: nouveau display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: MStar Demo serial: <filter>
    built: 2007 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 69 gamma: 1.2
    size: 708x398mm (27.87x15.67") diag: 1321mm (52") ratio: 16:9 modes:
    max: 1280x720 min: 640x480
  Info: Tools: de: xfce4-display-settings x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  Device-2: NVIDIA High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
  API: ALSA v: k6.16.7-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
    port: f040 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  Local Storage: total: 1.59 TiB used: 21.28 GiB (1.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC45 scheme: MBR
    model: WD5000AAKX-75U6AA0 size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 1H19 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT250MX500SSD1
    size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
  ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
    used: 21.28 GiB (9.1%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
  ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 48.0 C mobo: N/A gpu: nouveau temp: 51.0 C
  Memory: total: 16 GiB available: 15.55 GiB used: 2.31 GiB (14.8%)
  Processes: 248 Power: uptime: 2h 21m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 258 default: graphical tool: systemctl
  Packages: 1201 pm: pacman pkgs: 1195 libs: 339 tools: paru,yay pm: flatpak
    pkgs: 6 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3
    running-in: xfce4-terminal inxi: 3.3.39
Garuda (2.8.3-2):
  System install date:     2025-09-18
  Garuda release:          250916
  Last full system update: 2025-09-19
I don’t use xfce, but I believe that more details on this would help.
Go to System Settings > User accounts, click ā€œUnlockā€ and enter your password, then click the button next to ā€œAutomatic loginā€:
or 2.
Create a file /etc/lightdm/lightdm.conf and add the following content:
autologin-user=$user>
autologin-user-timeout=5
(don’t insert 0)
