Auto login selected
Recently installed the sway edition & selected auto-login in the installer. During boot, the login screen is presented.
Just new too tiling WM & trying to find a config file to change the behavior ...
Thanks for any advise.
Please, follow the template and post your
@GreenMartian, where did you go?
Very nice to see you back @GreenMartian. Unfortunately, I don't have any helpful advice for you, as I do not use any of the WM's. I've always been a KDE guy since day one.
Since Sway uses qtgreet, whatever autologin Calamares is trying to set up will not work. Autologin has to be specified in the greetd config file.
sudo micro /etc/greetd/config.toml
You can leave the file as it is, just skip down to the bottom and add a few lines like so:
[initial_session]
command = "sway"
user = "GreenMartian"
Reboot, enjoy not logging in. :slightly_smiling_face:
More: greetd - ArchWiki
right on!!!!
:smiley:
Thanks @BluishHumility and @tbg. Check in every now & then ... Garuda or Archlabs. I've jumped from Sway over to Fedora Plasma. You know how that goes! :wink:
Only too well…:smirk:
This was one of my very first distros, right after the obligatory Linux Mint installation. It will always have a place in my heart!
Enjoy, see you around. :slightly_smiling_face:
