╭─phantom@garuda in ~
╰─λ inxi -Faz
System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ec03565d-8e80-4014-a8cc-99d0281f1d50 rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Micro-Star product: Modern 15 A5M v: REV:1.0
Mobo: Micro-Star model: MS-155L v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E155LAMS.108 date: 07/28/2021
Battery: ID-1: BAT1 charge: 44.3 Wh (89.5%) condition: 49.5/52.4 Wh (94.3%) volts: 12.3
min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 17 (23) model-id: 68 (104) stepping: 1 microcode: 8608103 cache:
L1: 384 KiB L2: 3 MiB L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 50302
Speed: 1397 MHz min/max: 1400/2100 MHz boost: disabled Core speeds (MHz): 1: 1397
2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
12: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Graphics: Device-1: AMD Lucienne vendor: Micro-Star MSI driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Micro-Star MSI
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
Device-3: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-2: Lite-On Dell Wireless Device type: USB driver: hid-generic,usbhid
bus-ID: 3-2:2 chip-ID: 04ca:00ac class-ID: 0301
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 476.94 GiB used: 147.43 GiB (30.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFK52.8 temp: 30.9 C scheme: GPT
Partition: ID-1: / raw-size: 40 GiB size: 40 GiB (100.00%) used: 23.21 GiB (58.0%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 2.8 MiB (0.9%)
fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 50 GiB size: 50 GiB (100.00%) used: 19.02 GiB (38.0%) fs: btrfs
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 40 GiB size: 40 GiB (100.00%) used: 23.21 GiB (58.0%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 40 GiB size: 40 GiB (100.00%) used: 23.21 GiB (58.0%)
ID-1: swap-1 type: zram size: 7.19 GiB used: 4.67 GiB (64.9%) priority: 100
Sensors: System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Info: Processes: 432 Uptime: 6h 51m wakeups: 2536 Memory: 7.19 GiB used: 5.67 GiB (78.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1401 lib: 338 Shell: fish v: 3.3.1 running-in: alacritty inxi: 3.3.09
Hello, I am using msi modern 15. My screen brightness keeps auto adjusting I have tried everything but nothing seems to work. sometimes in low ambient light conditions screen goes full dim and vice versa. Even if I manually adjust the brightness after few seconds it will sart auto adjusitng itself. How can I turn this feature off
