Hi. I tried to install the AUR package but it could not download the build files. Next I tried to update mirrorlist, but the connection timed out. I tried to fix with the update remote fix command, but it didn’t work
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=bfc36042-8f8e-4781-beaa-4e24b4c8225c rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Micro-Star product: MS-7E27 v: 1.0 serial: N/A
Mobo: Micro-Star model: PRO B650M-P (MS-7E27) v: 1.0 serial: <filter>
uuid: 91e77887-6e0e-2b1f-a73a-d843ae5ca4e6 UEFI: American Megatrends LLC.
v: 1.B0 date: 07/25/2024
Info: model: AMD Ryzen 5 7600 socket: AM5 bits: 64 type: MT MCP arch: Zen 4
gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2988 min/max: 545/5170 boost: enabled
base/boost: 3800/5150 scaling: driver: amd-pstate-epp governor: performance
volts: 1.3 V ext-clock: 100 MHz cores: 1: 2988 2: 2988 3: 2988 4: 2988
5: 2988 6: 2988 7: 2988 8: 2988 9: 2988 10: 2988 11: 2988 12: 2988
bogomips: 91199
Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-1 bus-ID: 10:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 37.0 C
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 note: disabled model: V24FAB-RA serial: <filter>
built: 2022 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x293mm (20.75x11.54") diag: 603mm (23.7") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
SUPER/PCIe/SSE2 memory: 11.71 GiB
API: Vulkan v: 1.3.295 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 SUPER driver: nvidia v: 565.57.01 device-ID: 10de:2783
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 24.2.7-arch1.1
device-ID: 1002:164e surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM
Device-1: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
speed: 16 GT/s lanes: 16 bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: down mac: <filter>
Device-2: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-3: ASUSTek ASUS USB-AC58 USB Wireless adapter driver: rtl88x2bu
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1:2
chip-ID: 0b05:19aa class-ID: 0000 serial: <filter>
IF: wlan0 state: up mac: <filter>
Local Storage: total: 953.87 GiB used: 166.42 GiB (17.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 953.87 GiB block-size: physical: 512 B
fw-rev: 42BFU6MI temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 151d 11h cycles: 186
read-units: 65,482,648 [33.5 TB] written-units: 49,219,850 [25.2 TB]
ID-1: / raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
used: 166.07 GiB (69.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-2: /boot raw-size: 500 MiB size: 500 MiB (100.00%)
used: 325.1 MiB (65.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 34 MiB (35.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-4: /home raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
maj-min: 259:7
ID-5: /var/log raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
maj-min: 259:7
ID-6: /var/tmp raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
ID-2: swap-2 type: zram size: 30.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.1 C mobo: 33.5 C gpu: amdgpu temp: 38.0 C
Memory: total: 32 GiB note: est. available: 30.46 GiB used: 3.9 GiB (12.8%)
Processes: 401 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2011 libs: 578 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date: 2024-05-11
Last full system update: 2024-11-26
Windows dual boot: Yes
Failed units: samba.service
