Hello Garuda users.
here's my system
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_NZ.UTF-8",
LC_NAME = "en_NZ.UTF-8",
LC_MONETARY = "en_NZ.UTF-8",
LC_PAPER = "en_NZ.UTF-8",
LC_IDENTIFICATION = "en_NZ.UTF-8",
LC_TELEPHONE = "en_NZ.UTF-8",
LC_MEASUREMENT = "en_NZ.UTF-8",
LC_TIME = "Default.UTF-8",
LC_NUMERIC = "en_NZ.UTF-8",
LANG = "en_NZ.UTF-8"
perl: warning: Falling back to a fallback locale ("en_NZ.UTF-8").
Kernel: 5.18.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=1b6c0a30-a1a9-4674-ab29-9bd72b32b4fd rw [email protected]
Type: Desktop System: Hewlett-Packard product: HP Pro 3000/3080 v: N/A
serial: N/A Chassis: type: 3 serial: N/A
Mobo: MICRO-STAR model: 3664h serial: N/A BIOS: American Megatrends
v: 1.04 date: 12/01/2009
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
Info: model: Intel Core2 Duo E7600 socket: LGA775 bits: 64 type: MCP
arch: Core Yorkfield family: 6 model-id: 0x17 (23) stepping: 0xA (10)
microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3066 min/max: 1603/3066 base/boost: 3066/3066 scaling:
driver: acpi-cpufreq governor: performance volts: 1.3 V ext-clock: 1066 MHz
cores: 1: 3066 2: 3066 bogomips: 12236
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: Gigabyte driver: radeon v: kernel alternate: amdgpu pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1,VGA-1 empty: DVI-D-1,DVI-D-2 bus-ID: 01:00.0
chip-ID: 1002:683f class-ID: 0300
Device-2: Arkmicro Webcam Carrefour type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5:2 chip-ID: 18ec:3299
class-ID: 0102
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-0 pos: right model: Samsung built: 2010
res: 1920x1080 hz: 60 dpi: 305 gamma: 1.4 size: 160x90mm (6.3x3.54")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1360x768 min: 720x400
Monitor-2: VGA-1 mapped: VGA-0 pos: primary,left model: Dell E2211H
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
OpenGL: renderer: AMD VERDE (LLVM 13.0.1 DRM 2.50 5.18.2-zen1-1-zen)
v: 4.5 Mesa 22.1.1 direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: Arkmicro Webcam Carrefour type: USB
class-ID: 0102
Sound Server-1: ALSA v: k5.18.2-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Edimax N150 Adapter type: USB driver: r8188eu bus-ID: 3-3:2
chip-ID: 7392:b811 class-ID: 0000 serial: <filter>
IF: wlp4s1f2u3 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 11-2:2 chip-ID: 0a12:0001 class-ID: e001
Hardware-1: Silicon Image SiI 3114 [SATALink/SATARaid] Serial ATA Controller driver: sata_sil v: 2.4 port: e400 bus-ID: 04:00.0 chip-ID: 1095:3114
rev: N/A class-ID: 0104
Local Storage: total: 2.46 TiB used: 829.4 GiB (33.0%)
model: WD20EADS-00W4B0 family: Caviar Green size: 1.82 TiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: N/A
serial: <filter> rev: 0A01 temp: 29 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 14d 12h cycles: 5090
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3200822A
family: Barracuda 7200.7 and 7200.7 Plus size: 186.31 GiB block-size:
physical: 512 B logical: 512 B speed: 1.5 Gb/s type: N/A serial: <filter>
rev: 3.01 temp: 30 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 281d 5h cycles: 11459
Old-Age: UDMA CRC errors: 1072 alert: Bad cable/connection? Pre-Fail:
reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500418AS
family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 1.5 Gb/s type: HDD rpm: 7200
serial: <filter> rev: HP35 temp: 29 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 77d 0h cycles: 44963
Pre-Fail: reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
ID-1: / raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
used: 116.05 GiB (62.3%) fs: btrfs block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17
ID-2: /home raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
maj-min: 8:17
ID-3: /var/log raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
maj-min: 8:17
ID-4: /var/tmp raw-size: 186.31 GiB size: 186.31 GiB (100.00%)
maj-min: 8:17
ID-1: swap-1 type: zram size: 3.83 GiB used: 285.5 MiB (7.3%)
System Temperatures: cpu: 36.0 C mobo: N/A gpu: radeon temp: 42.0 C
Processes: 230 Uptime: 36m wakeups: 2 Memory: 3.83 GiB
used: 2.09 GiB (54.5%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1929 lib: 551
inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-31
Last full system update: 2022-06-09
here is my problem
Unable to create io-slave. Unknown protocol 'audiocd'.
at this point i have not tried anything as the issue has just appeared. any suggestions
cheers
