Was audio changed with the last update?
I cant go to settings>Audio>and put audio level above 100%
100% is the highest it'll go.
My laptop has pretty low audio, I have bad hearing also, so it helps putting audio at 130%.
where garuda-inxi?
Sorry I rarely have issues and forgot about this. In my opinion nothing is broken, Iām just deaf and need it to be louder.
mdoverl@mdoverl in ~
ā°āĪ» garuda-inxi
Kernel: 6.2.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=fae2eeb3-5612-408c-9d4e-749b6c3448cb rw rootflags=subvol=@
resume=UUID=4f532041-9bce-4418-b7d5-4b9fdfba3d44 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TP501UAM v: 1.0
serial:
Mobo: ASUSTeK model: TP501UAM v: 1.0 serial:
UEFI: American Megatrends v: TP501UAM.201 date: 04/18/2016
ID-1: BAT0 charge: 16.5 Wh (100.0%) condition: 16.5/38.0 Wh (43.3%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 114
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2667 high: 2791 min/max: 400/2800 scaling:
driver: intel_pstate governor: performance cores: 1: 2777 2: 2400 3: 2700
4: 2791 bogomips: 19200
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 04f2:b496 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c4 built: 2013 res: 1920x1080
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.2.2-zen2-1-zen running: yes
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac:
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp2s0 state: down mac:
bus-ID: 1-8:6 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address:
Local Storage: total: 931.51 GiB used: 359.49 GiB (38.6%)
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: rev: 00WD
ID-1: / raw-size: 918.98 GiB size: 918.98 GiB (100.00%)
used: 359.49 GiB (39.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 918.98 GiB size: 918.98 GiB (100.00%)
ID-4: /var/log raw-size: 918.98 GiB size: 918.98 GiB (100.00%)
ID-5: /var/tmp raw-size: 918.98 GiB size: 918.98 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.12 GiB used: 621.2 MiB (5.5%)
ID-2: swap-2 type: partition size: 12.24 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C pch: 47.5 C mobo: N/A
Fan Speeds (RPM): cpu: 3400
Processes: 257 Uptime: 2d 19h 51m wakeups: 11 Memory: 11.12 GiB
used: 4.68 GiB (42.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 2159 pm: pacman pkgs: 2152
libs: 597 tools: octopi,pamac,paru pm: appimage pkgs: 0 pm: flatpak pkgs: 7
Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-12-10
Last full system update: 2023-03-16 ā»
Among the KDE audio settings, there is a checkbox that allows you to go over 100% volume. I really cannot recommend that though, as it causes a lot of distortion.
Thank you, that was it. I'm not worried about distortion because I need to be able to hear what I'm listening to.
You might want to try a hardware audio amplifier for that. They seem to go mostly without distortion and can go very loud. They do however require analog headphones to my knowledge
Edit: E.g. the Chord Mojo (I don't know really many more, all my knowledge regarding that is from DankPods blowing up headphones lol)
There is a risk of blowing out your speakers when you push your audio past 100%. Some people have been made very sorry over the years from doing this. Fair warning to those using this option that it comes with the potential for damaging your hardware.
We have gotten some user complaints in the past blaming the damage on the distro. If you choose to implement this option and you damage your audio hardware that's on you, (not the distro). Just a word of caution for those thinking of using this option with a set of fairly expensive speakers, (you may regret it).
"Why don't you just make ten louder, and make ten be the top number, and make that a little louder?"
"...These go to eleven."
