Audio through Bluetooth Only on Pipewire
Recently the audio from my laptop speakers and headphone jack has stopped working entirely. I can play audio successfully via Bluetooth, but nothing physically connected to the laptop. I’ve tried switch to Pulse from Pipewire, which seems to be the most common solution when I’ve searched this, and I’ve not had any luck with that. I’ve made sure the audio output is set to "Speaker (Family 17H/19H HD Audio Controller Speaker) and I can’t even get a test sound to play.
Kernel: 6.10.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a28b6008-ae1b-4eb7-a1fd-b6cff1cd078e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: Micro-Star product: Bravo 15 C7VFKP v: REV:1.0
Mobo: Micro-Star model: MS-158N v: REV:1.0 serial: <superuser required>
part-nu: 158N.3 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E158NAMS.30E date: 07/27/2023
ID-1: BAT1 charge: 50.6 Wh (100.0%) condition: 50.6/52.0 Wh (97.2%)
volts: 12.9 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
microcode: 0xA704103
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 681 high: 1930 min/max: 400/5263 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 1349 3: 1930
4: 1397 5: 400 6: 400 7: 400 8: 400 9: 400 10: 1421 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 127756
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: Micro-Star MSI driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0
chip-ID: 10de:28a0 class-ID: 0300
Device-2: AMD Phoenix1 vendor: Micro-Star MSI driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4,
DP-5, DP-6, DP-7, DP-8, DP-9, Writeback-1 bus-ID: 05:00.0
chip-ID: 1002:15bf class-ID: 0300 temp: 51.0 C
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 30c9:0042
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-2 res: 1536x864 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
gfx1103_r1 LLVM 18.1.8 DRM 3.57 6.10.3-zen1-2-zen) device-ID: 1002:15bf
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: mesa radv v: 24.1.5-arch1.1
device-ID: 1002:15bf surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia
v: 555.58.02 device-ID: 10de:28a0 surfaces: xcb,xlib,wayland device: 2
v: 24.1.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
API: ALSA v: k6.10.3-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0e8d:0608
Local Storage: total: 953.87 GiB used: 650.68 GiB (68.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA1T0QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA001 temp: 44.9 C
used: 650.68 GiB (68.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 14.81 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.4 C mobo: 42.0 C gpu: amdgpu temp: 53.0 C
Memory: total: 16 GiB note: est. available: 14.81 GiB used: 4.1 GiB (27.7%)
Processes: 420 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
image: 5.88 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1953 libs: 578 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-07-24
Last full system update: 2024-08-10
