I have been using my garuda system with no issues for a few months, however this morning I was watching some videos on youtube and in the middle of a video audio completely cut off. This isn’t just a youtube issue, I also get no audio in games or with the test sounds through KDE system settings. I have tried multiple audio output devices to rule out that my headphones are the issue, but I get no audio with any of them.
After the audio dropped out I tried rebooting my system, updating packages, reinstalling pipewire, using garuda assistant to switch to pulseaudio and back, and using garuda assistant to restart all packages, however none of those have resolved the issue, I’m not sure what the next step in troubleshooting this should be.
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8eb18497-02ac-4915-ad59-2728901f9720 rw rootflags=subvol=@
quiet rd.luks.uuid=2d2dd9af-e4d5-43bb-9211-ebf1bc553aab quiet
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3498 high: 3600 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3599 2: 3598
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3600 9: 3598 10: 3400 11: 3400
12: 3400 13: 3597 14: 3599 15: 3595 16: 3595 bogomips: 108807
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 0c:00.0
chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu d-rect: 7680x1440 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: center res: 2560x1440 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: right res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.1-arch1.1
navi22 LLVM 16.0.6 DRM 3.54 6.6.7-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.274 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.3.1-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Audeze Maxwell Dongle driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:4
chip-ID: 3329:4b19 class-ID: 0102 serial: <filter>
Device-4: Razer USA RZ19-0229 Gaming Microphone
lanes: 1 mode: 1.1 bus-ID: 5-3.4:6 chip-ID: 1532:0511 class-ID: 0300
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 168c:0034 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:3 chip-ID: 0489:e076
rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 5.2 TiB used: 1.25 TiB (24.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.3 temp: 46.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR402 temp: 38.9 C
ID-3: /dev/nvme2n1 maj-min: 259:5 model: PCIe SSD size: 931.51 GiB
tech: SSD serial: <filter> fw-rev: EHFM31.1 temp: 45.9 C scheme: MBR
ID-4: /dev/sda maj-min: 8:0 vendor: A-Data model: SP550 size: 223.57 GiB
serial: <filter> fw-rev: 3B5a scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Mushkin model: MKNSSDCR480GB-7-A
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 290.35 GiB (31.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2d2dd9af-e4d5-43bb-9211-ebf1bc553aab
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 63.5 MiB (0.2%)
System Temperatures: cpu: 36.0 C mobo: 39.0 C gpu: amdgpu temp: 58.0 C
mem: 62.0 C
Processes: 578 Uptime: 19m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 7.86 GiB (25.2%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1656
pm: pacman pkgs: 1651 libs: 483 tools: octopi,paru pm: flatpak pkgs: 5
Shell: fish v: 3.6.4 default: Bash v: 5.2.21 running-in: yakuake
inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-10-23
Last full system update: 2023-12-20 ↻
