I boot up and audio is working fine. I plug-in my headphones (To the 1/8 inch headphone jack) and audio is working fine. If I then unplug my headphones, all audio output (Input seems to be okay) stops working until the next reboot.
I'm a bit rusty troubleshooting audio because I've only been admining Linux servers for the past year, until now. This is a fresh install.
inxi:
Kernel: 6.0.1-zen2-1-zen
arch: x86_64
bits: 64
compiler: gcc
v: 12.2.0
root=UUID=cc8f8aae-9afb-48fc-9eff-62f9df1eb56c
rw
rootflags=subvol=@
quiet
cryptdevice=UUID=cfffcf8a-c3da-46b8-b9c9-b4bc281caba8:luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
root=/dev/mapper/luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
quiet
splash
rd.udev.log_priority=3
vt.global_cursor_default=0
resume=/dev/mapper/luks-4a58206a-a094-481e-8f36-013e250bfae4
Desktop: GNOME
v: 42.5
tk: GTK
v: 3.24.34
wm: gnome-shell
dm: GDM
v: 42.0
Distro: Garuda Linux
Type: Laptop
System: ASUSTeK
product: ROG
Zephyrus
G15
GA503RM_GA503RM
v: 1.0
Mobo: ASUSTeK
model: GA503RM
v: 1.0
UEFI: American
Megatrends
LLC.
v: GA503RM.310
date: 09/12/2022
ID-1: BAT1
charge: 87.4
Wh
(100.0%)
condition: 87.4/90.2
Wh
(96.9%)
volts: 17.3
min: 15.9
model: ASUS A32-K55
type: Li-ion
serial: N/A
status: full
model: AMD
Ryzen
9
6900HS
with
Radeon
Graphics
bits: 64
type: MT MCP
arch: Zen 3+
gen: 4
level: v3
note: check
built: 2022
process: TSMC
n6
(7nm)
family: 0x19 (25)
model-id: 0x44 (68)
stepping: 1
microcode: 0xA404101
Topology:
cpus: 1x
cores: 8
tpc: 2
threads: 16
smt: enabled
cache:
L1: 512 KiB
desc: d-8x32
KiB;
i-8x32
KiB
L2: 4 MiB
desc: 8x512 KiB
L3: 16 MiB
desc: 1x16 MiB
Speed (MHz):
avg: 1559
high: 2370
min/max: 1600/4934
boost: enabled
scaling:
driver: acpi-cpufreq
governor: schedutil
cores:
1: 1588
2: 2370
3: 1900
4: 1349
5: 1368
6: 1600
7: 1600
8: 1600
9: 1345
10: 1600
11: 1326
12: 1341
13: 1396
14: 1600
15: 1365
16: 1600
bogomips: 105410
Flags: avx
avx2
ht
lm
nx
pae
sse
sse2
sse3
sse4_1
sse4_2
sse4a
ssse3
svm
Type: itlb_multihit
status: Not affected
Type: l1tf
Type: mds
Type: meltdown
Type: mmio_stale_data
Type: retbleed
mitigation: Speculative
Store
Bypass
disabled
via
mitigation: usercopy/swapgs
barriers
and
__user
pointer
mitigation: Retpolines,
IBPB:
conditional,
IBRS_FW,
STIBP:
always-on,
RSB
filling,
PBRSB-eIBRS:
Not
affected
Type: srbds
Type: tsx_async_abort
Device-1: NVIDIA
GA106M
[GeForce
RTX
3060
Mobile
Max-Q]
vendor: ASUSTeK
driver: nvidia
v: 520.56.06
alternate: nouveau,nvidia_drm
non-free: 515.xx+
status: current
(as
of
2022-10)
arch: Ampere
code: GAxxx
process: TSMC
n7
(7nm)
built: 2020-22
pcie:
gen: 1
speed: 2.5 GT/s
lanes: 8
link-max:
gen: 4
speed: 16 GT/s
lanes: 16
bus-ID: 01:00.0
chip-ID: 10de:2520
Device-2: AMD
Rembrandt
[Radeon
680M]
vendor: ASUSTeK
driver: amdgpu
v: kernel
arch: RDNA-2
code: Navi-2x
process: TSMC
n7
(7nm)
built: 2020-22
pcie:
gen: 4
speed: 16 GT/s
lanes: 16
ports:
active: eDP-1
empty: DP-1,
DP-2,
DP-3,
DP-4,
DP-5,
DP-6,
DP-7,
DP-8
bus-ID: 07:00.0
chip-ID: 1002:1681
temp: 49.0 C
Device-3: IMC
Networks
USB2.0
HD
UVC
WebCam
type: USB
driver: uvcvideo
bus-ID: 5-1:2
chip-ID: 13d3:56eb
class-ID: fe01
Display: x11
server: X.Org
v: 21.1.4
with: Xwayland
v: 22.1.3
compositor: gnome-shell
driver:
X:
loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon
alternate: fbdev,nv,vesa
dri: radeonsi
gpu: amdgpu
display-ID: :1
Screen-1: 0
s-res: 2560x1440
s-dpi: 96
s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: eDP-1
mapped: eDP
model: ChiMei
InnoLux
0x1540
built: 2020
res: 2560x1440
hz: 165
dpi: 189
gamma: 1.2
size: 344x193mm (13.54x7.6")
diag: 394mm (15.5")
ratio: 16:9
modes:
max: 2560x1440
min: 640x480
Message: Unable
to
show
GL
data.
Required
tool
glxinfo
missing.
Device-1: NVIDIA
GA106
High
Definition
Audio
vendor: ASUSTeK
driver: snd_hda_intel
v: kernel
pcie:
gen: 1
speed: 2.5 GT/s
lanes: 8
link-max:
gen: 4
speed: 16 GT/s
lanes: 16
bus-ID: 01:00.1
chip-ID: 10de:228e
Device-2: AMD
Rembrandt
Radeon
High
Definition
Audio
vendor: ASUSTeK
v: kernel
pcie:
gen: 4
speed: 16 GT/s
lanes: 16
bus-ID: 07:00.1
chip-ID: 1002:1640
Device-3: AMD
ACP/ACP3X/ACP6x
Audio
Coprocessor
vendor: ASUSTeK
driver: snd_pci_acp6x
v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
pcie:
gen: 4
speed: 16 GT/s
lanes: 16
bus-ID: 07:00.5
chip-ID: 1022:15e2
class-ID: 0480
Device-4: AMD
Family
17h/19h
HD
Audio
vendor: ASUSTeK
v: kernel
pcie:
gen: 4
speed: 16 GT/s
lanes: 16
bus-ID: 07:00.6
chip-ID: 1022:15e3
Sound API: ALSA
v: k6.0.1-zen2-1-zen
running: yes
Sound Server-1: PulseAudio
v: 16.1
running: no
Sound Server-2: PipeWire
v: 0.3.59
running: yes
Device-1: Realtek
RTL8125
2.5GbE
vendor: ASUSTeK
driver: r8169
v: kernel
pcie:
gen: 2
speed: 5 GT/s
lanes: 1
port: e000
bus-ID: 03:00.0
chip-ID: 10ec:8125
IF: eno1
state: down
mac: <filter>
Device-2: MEDIATEK
vendor: AzureWave
driver: mt7921e
v: kernel
pcie:
gen: 2
speed: 5 GT/s
lanes: 1
port: N/A
bus-ID: 04:00.0
chip-ID: 14c3:7922
IF: wlp4s0
state: up
mac: <filter>
IF-ID-1: anbox0
state: down
mac: <filter>
IF-ID-2: wg0
state: unknown
speed: N/A
duplex: N/A
mac: N/A
Device-1: IMC
Networks
Wireless_Device
type: USB
driver: btusb
v: 0.8
bus-ID: 3-3:3
chip-ID: 13d3:3568
Report: bt-adapter
rfk-id: 2
state: up
address: <filter>
Local Storage:
total: 1.38 TiB
used: 366.9
GiB
(26.0%)
SMART Message: Required
tool
smartctl
not
installed.
Check
--recommends
ID-1: /dev/nvme0n1
maj-min: 259:0
vendor: Smart
Modular
Tech.
model: SHPP41-1000GM
block-size:
physical: 512 B
logical: 512 B
speed: 63.2 Gb/s
lanes: 4
type: SSD
rev: 51060A20
temp: 55.9 C
ID-2: /dev/nvme1n1
maj-min: 259:7
vendor: Western Digital
model: WD
PC
SN735
SDBPNHH-512G-1002
block-size:
physical: 512 B
logical: 512 B
speed: 63.2 Gb/s
lanes: 4
type: SSD
rev: 70626000
temp: 44.9 C
ID-1: /
raw-size: 451.59 GiB
GiB
(100.00%)
used: 46.7
GiB
(10.3%)
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
mapped: luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
ID-2: /boot/efi
raw-size: 300 MiB
MiB
(99.80%)
used: 752
KiB
(0.2%)
fs: vfat
dev: /dev/nvme1n1p1
maj-min: 259:8
ID-3: /home
GiB
(100.00%)
used: 46.7
GiB
(10.3%)
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
ID-4: /var/log
GiB
(100.00%)
used: 46.7
GiB
(10.3%)
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
ID-5: /var/tmp
GiB
(100.00%)
used: 46.7
GiB
(10.3%)
fs: btrfs
dev: /dev/dm-0
maj-min: 254:0
Kernel:
swappiness: 133
(default
60)
cache-pressure: 100 (default)
ID-1: swap-1
type: zram
used: 1.71
GiB
(7.5%)
priority: 100
ID-2: swap-2
type: partition
used: 0
KiB
(0.0%)
priority: -2
dev: /dev/dm-1
maj-min: 254:1
mapped: luks-4a58206a-a094-481e-8f36-013e250bfae4
System Temperatures:
cpu: 52.1 C
mobo: N/A
gpu: amdgpu
temp: 49.0 C
Fan Speeds (RPM):
cpu: 3100
Processes: 454
Uptime: 2h 11m
wakeups: 29
Memory: 22.77 GiB
used: 7.86
GiB
(34.5%)
Init: systemd
v: 251
default: graphical
Compilers:
gcc: 12.2.0
clang: 14.0.6
Packages:
pm: pacman
pkgs: 1542
libs: 404
tools: gnome-software,pamac,paru
Shell: fish
v: 3.5.1
default: Bash
v: 5.1.16
running-in: gnome-terminal
inxi: 3.3.22
e[1;34mGaruda (2.6.8-1):e[0m
e[1;34m System install date:e[0m 2022-10-15
e[1;34m Last full system update:e[0m 2022-10-15 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m systemd-networkd-wait-online.service
