After this last update, sound output has vanished. I do see a Pro Audio option but getting no sound on output. Providing inxi below:
╭─reggie@garudak in ~
╰─λ garuda-inxi
Kernel: 6.8.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=67603faa-4625-4bc5-9143-6953c6802191 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Convertible System: Dell product: Latitude 9520 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0GVMP9 v: A03 serial: <superuser required> part-nu: 0A3F
uuid: <superuser required> UEFI: Dell v: 1.30.1 date: 03/22/2024
ID-1: BAT0 charge: 34.2 Wh (84.9%) condition: 40.3/47.8 Wh (84.2%)
volts: 8.5 min: 7.6 model: BYD DELL F68NR22 type: Li-poly serial: <filter>
status: charging
Device-1: hidpp_battery_0 model: Logitech M510 serial: <filter>
Device-2: hidpp_battery_1 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
microcode: 0xB6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2068 high: 3949 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1172 2: 1916 3: 3949
4: 1161 5: 2533 6: 2068 7: 3348 8: 400 bogomips: 28876
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: DP-3, DP-4, DP-5, eDP-1 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0c45:672d
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.84x11.22")
s-diag: 1546mm (60.89")
Monitor-1: DP-3 mapped: DP-1-1 pos: left model: BenQ GW2760HS
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: DP-4 mapped: DP-1-2 pos: center model: Synaptics Non-PnP
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x290mm (20.87x11.42") modes: max: 1024x768 min: 720x400
Monitor-3: DP-5 mapped: DP-1-3 pos: right model: BenQ GW2760HS
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-4: eDP-1 pos: primary,left model: AU Optronics 0xfb91 built: 2020
res: 1920x1080 hz: 60 dpi: 147 gamma: 1.2 size: 331x186mm (13.03x7.32")
diag: 380mm (14.9") ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.99 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Device-2: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1.3.3.4:13
chip-ID: 001f:0b21 class-ID: 0300 serial: <filter>
API: ALSA v: k6.8.5-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.4.4:5
IF: enp0s13f0u1u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.1.3.3.1:11
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 183.28 GiB (38.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM991a NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 26304039 temp: 31.9 C
used: 183.22 GiB (38.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 58.7 MiB (19.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 8.14 GiB (53.0%)
Processes: 418 Power: uptime: 22h 33m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: 1861 pm: pacman pkgs: 1815 libs: 483 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 46 Compilers: gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
Garuda (2.6.25-1):
System install date: 2024-04-04
Last full system update: 2024-04-14 ↻
