Audio/sound playback device is not shown after update of Garuda GNOME version
After running the latest update on 28. 11.2024, the audio playback device disappeared in the GNOME settings and audio playback is not possible. I tried booting with the LTS kernel, but that did not fix the issue. The update appears to include a new NVIDIA driver and the update to GNOME 46.
Going back to a snapshot before the update fixes it, but at some point in time I’d like to keep my Garuda up to date. If anybody knows what else I could try, I’d be grateful for advice.
  Kernel: 6.8.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=9e91aed5-80b5-4f9d-ab1a-682ed4959ce3 rw rootflags=subvol=@
    quiet rd.luks.uuid=84e9c09a-028a-4dab-9ba0-f6f4264ca96b
    rd.luks.uuid=079b9492-6893-4fe7-a3b5-89020f404766
    resume=/dev/mapper/luks-079b9492-6893-4fe7-a3b5-89020f404766 loglevel=3
  Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Garuda base: Arch Linux
  Type: Laptop System: HUAWEI product: MACH-WX9 v: M1A
  Mobo: HUAWEI model: MACH-WX9-PCB v: M1A serial: <superuser required>
    part-nu: C100 uuid: <superuser required> UEFI: HUAWEI v: 1.37
    date: 05/12/2021
  ID-1: BAT0 charge: 49.9 Wh (99.2%) condition: 50.3/56.3 Wh (89.3%)
    volts: 7.9 min: 7.6 model: DYNAPACK HB4593R1ECW-22T0 type: Li-ion
    serial: <filter> status: not charging cycles: 24
  Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
    model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 565 high: 881 min/max: 400/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 845 2: 800 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 881 bogomips: 31999
  Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
  Device-2: NVIDIA GP108M [GeForce MX150] vendor: Huawei driver: nvidia
    v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d12
    class-ID: 0302
  Device-3: Cheng Uei Precision Industry (Foxlink) HD Camera
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-7:3 chip-ID: 05c8:03c0 class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3000x2000 s-dpi: 96 s-size: 793x529mm (31.22x20.83")
    s-diag: 953mm (37.53")
  Monitor-1: eDP-1 model-id: JDI 0x422a built: 2017 res: 3000x2000 hz: 60
    dpi: 260 gamma: 1.2 size: 293x196mm (11.54x7.72") diag: 353mm (13.9")
    ratio: 3:2 modes: 3000x2000
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.0.3-arch1.2
    device-ID: 8086:5917 surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce MX150 driver: nvidia v: 550.67 device-ID: 10de:1d12
    surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 17.0.6 256
    bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM 17.0.6)
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Huawei
  API: ALSA v: k6.8.2-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0
    chip-ID: 8086:24fd class-ID: 0280
  IF: wlp60s0 state: up mac: <filter>
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 8087:0a2b
  Local Storage: total: 476.94 GiB used: 388.66 GiB (81.5%)
    model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: EXA7301Q temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 459.72 GiB size: 459.72 GiB (100.00%)
    used: 388.66 GiB (84.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-84e9c09a-028a-4dab-9ba0-f6f4264ca96b
    used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 459.72 GiB size: 459.72 GiB (100.00%)
  ID-4: /var/log raw-size: 459.72 GiB size: 459.72 GiB (100.00%)
  ID-5: /var/tmp raw-size: 459.72 GiB size: 459.72 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%)
    mapped: luks-079b9492-6893-4fe7-a3b5-89020f404766
  ID-2: swap-2 type: zram size: 15.37 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 52.0 C pch: 46.5 C mobo: N/A
  Memory: total: 16 GiB note: est. available: 15.37 GiB used: 3.68 GiB (23.9%)
  Processes: 309 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.11 GiB services: gsd-power,
  Packages: 1816 pm: pacman pkgs: 1806 libs: 482 tools: pamac,paru,yay
    pm: flatpak pkgs: 10 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash
    v: 5.2.26 running-in: gnome-terminal inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2023-12-03
  Last full system update: 2024-03-28
This is the configuration before the update:
  Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
  Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Garuda
    date: 05/12/2021
  ID-1: BAT0 charge: 49.9 Wh (99.0%) condition: 50.4/56.3 Wh (89.5%)
  Speed (MHz): avg: 550 high: 800 min/max: 400/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 800 3: 800 4: 400
    5: 400 6: 800 7: 400 8: 400 bogomips: 31999
    v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    class-ID: 0302
    UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.0.3-arch1.1
    name: NVIDIA GeForce MX150 driver: nvidia v: 550.54.14
    device-ID: 10de:1d12 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
    (LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM
  API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api tools: N/A
  Local Storage: total: 476.94 GiB used: 388.37 GiB (81.4%)
    fw-rev: EXA7301Q temp: 44.9 C scheme: GPT
    used: 388.37 GiB (84.5%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
  System Temperatures: cpu: 55.0 C pch: 50.5 C mobo: N/A
  Memory: total: 16 GiB note: est. available: 15.37 GiB used: 2.84 GiB (18.5%)
  Processes: 306 Power: uptime: 1m states: freeze,mem,disk suspend: deep
  Packages: 1811 pm: pacman pkgs: 1801 libs: 482 tools: pamac,paru,yay
Garuda (2.6.23-1):
  Last full system update: 2024-03-16
  Is partially upgraded:   Yes
Fix this before anything else. This is a dangerous system condition.
Can you load a previous working snapshot?
Otherwise I got nothing. You got the 2 banes of Arch Linux – GNOME & NVIDIA.
Yes, I was able to load the snapshot prior to the update.
The partial update bit is referring to the status of the previous working snapshot.
I tried a fresh install on an external SSD and this upgraded without the sound issue. So I am afraid, I need to do a fresh install on the internal drive.
During the re-install of Garuda, I found out what went wrong. I did have a flatpak package installed with GNOME 45 dependencies (VideoDownloader). I assume that this messed up the GNOME 46 of the latest Garuda update. A fresh Garuda install without this flatpak package fixed it.
I guess if your only tool is a hammer…
