Audio problems on HP ENVY TS 17 Notebook
I have tried Pulse Audio and Alsa, neither seem to work in getting my audio to a reasonable volume.
I had HDA jack retask on Ubuntu which seemed to worked fined before I distrohopped.
I can't seem to have it work on this new build.
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=620f0643-878d-4ec5-a70b-977875c64a5f rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: Hewlett-Packard product: HP ENVY TS 17 Notebook PC
v: 097F110000405E00000620000 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 1968 v: KBC Version 93.52
serial: <superuser required> UEFI: Insyde v: F.70 date: 10/20/2017
ID-1: BAT0 charge: 28.4 Wh (69.4%) condition: 40.9/40.9 Wh (100.0%)
volts: 12.6 min: 11.1 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3023 high: 3400 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2395 2: 3400 3: 3400
4: 2395 5: 3400 6: 3400 7: 2395 8: 3400 bogomips: 38311
Device-1: Intel 4th Gen Core Processor Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-5.75
process: Intel 45nm built: 2010 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.0 chip-ID: 10de:1341
class-ID: 0302
Device-3: Suyin HP Truevision HD type: USB driver: uvcvideo bus-ID: 2-7:2
chip-ID: 064e:9301 class-ID: 0e02 serial: <filter>
alternate: fbdev,intel,nv,vesa dri: crocus gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: AU Optronics 0x219d built: 2011 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
chip-ID: 8086:8c20 class-ID: 0403
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter vendor: Hewlett-Packard
driver: rtl8188ee v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000
bus-ID: 08:00.0 chip-ID: 10ec:8179 class-ID: 0280
lanes: 1 port: 3000 bus-ID: 10:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.82 TiB used: 1005.01 GiB (53.9%)
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0004 scheme: GPT
ID-1: / raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
used: 51.39 GiB (42.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 429 MiB size: 428.1 MiB (99.80%)
used: 4.1 MiB (0.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
ID-4: /var/log raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
ID-5: /var/tmp raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.69 GiB used: 1.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 262 Uptime: 48m wakeups: 1 Memory: 7.69 GiB
used: 3.66 GiB (47.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1897
libs: 546 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date:     2022-11-18
Last full system update: 2022-11-19
What do you mean when you say you tried them? What specifically did you try?
Updating and or installing pulse audio as suggested didn't resolve the matter.
Tweaking Almixer too, didn't appear to resolve it.
Hmm, okay well so far we know basically nothing because all the information in the thread so far is too vague to be meaningful.
Did you try this? PipeWire - ArchWiki
