Audio problem with bluetooth connection
Hi everyone, I have a problem with my bluetooth headphones.
I can connect the headphones (although sometimes I have to unpair and pair again) but once the headphones are connected, the audio constantly stops playing, not allowing me to hear well.
I attach the output of the garuda-inxi command
note: having dual boot, this only happens when using garuda linux, on windows it works correctly
Kernel: 6.6.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9bfdd030-1f2b-4093-8a17-2b4630d976e5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: HP product: HP Laptop 15-dw1xxx v: Type1ProductConfigId
Mobo: HP model: 85F2 v: 37.29 serial: <superuser required> UEFI: Insyde
v: F.53 date: 10/15/2021
ID-1: BAT1 charge: 35.0 Wh (100.6%) condition: 34.8/41.0 Wh (84.8%)
volts: 12.6 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1432 high: 4555 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 4501 2: 400 3: 400
4: 4555 5: 400 6: 400 7: 400 8: 400 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
status: current (as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:174d
class-ID: 0302
Device-3: IMC Networks HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:56c9
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.3
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
device-ID: 8086:9b41 memory: 7.39 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9b41 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce MX130 driver: nvidia v: 545.29.06
device-ID: 10de:174d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api tools: N/A
lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0bda:b00a
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 585 GiB used: 41.79 GiB (7.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: SSSTC model: CV8-8E128-HP
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: V881 scheme: GPT
ID-1: / raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
used: 41.79 GiB (11.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
ID-4: /var/log raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
ID-5: /var/tmp raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 1.69 GiB (22.4%)
System Temperatures: cpu: 95.0 C pch: 56.0 C mobo: N/A
Processes: 270 Uptime: 55m wakeups: 0 Memory: total: 8 GiB
available: 7.56 GiB used: 3.09 GiB (40.8%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1383 libs: 405 tools: octopi,paru,yay Shell: fish
v: 3.6.4 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-10-21
Last full system update: 2023-12-14
What model bluetooth headset is it?
Try a garuda-update and reboot and try again. There has been bluetooth related packages that updated recently.
Heyyo!
I would suggest you the following steps:
  1. Open Garuda Assistant
  2. Select PipeWire Support
  3. Open terminal → install alsamixer via pacman
  4. Reboot
Now your Bluetooth sound forward will work (if it doesn’t just unplug Jack)
xiaomi redmi buds 3 lite
At the moment it seems to be working. Usually the problem occurs when I use Windows and then I use Linux. I disabled windows fast startup, hope it works in the long run!
EDIT:
Please note: The solution that definitely seems to work on my system is the following:
When I log in to Windows and use Bluetooth earphones, before turning off the PC, I go to Bluetooth settings and click on “forget device”, Windows probably releases the resources in this way but I’m not entirely sure about this.
Anyway, it’s working and I haven’t had any more problems with the headphones
I hope someone can benefit from this solution
p.s: I also disabled Windows fast startup
