I am having problem with the audio on my system, Each time I start my PC and try to play something nothing cam out of the speaker.when i do pulseaudio -k the sound came back, but after that when i restart the PC again the same problem is there.
These are my system information
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2c3e9637-10ef-4bc0-90bb-0b245dbe8da9
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: Latitude E6420 v: 01 serial: <filter> Chassis: type: 9
Mobo: Dell model: N/A serial: <filter> BIOS: Dell v: A14 date: 07/11/2012
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
This is confusing me, why do you have pipewire and pulse simultaneously working, like how according to me they are in conflict. Did you manually install pulseaudio?
no i have not installed pulse audio.
As per my knowledge garuda only uses pipewire, try unijstalling pulse
there is no conflict between them
[root@aaryan-latitudee6420 aaryan]# pacman -Qi pipewire
Version : 1:0.3.33-1
Description : Low-latency audio/video router and processor
Architecture : x86_64
URL : https://pipewire.org
Licenses : MIT LGPL
Groups : None
Provides : libpipewire-0.3.so=0-64
Depends On : rtkit alsa-card-profiles libdbus-1.so=3-64 libncursesw.so=6-64
libsndfile.so=1-64 libudev.so=1-64 libusb-1.0.so=0-64 libasound.so=2-64
libsystemd.so=0-64 libbluetooth.so=3-64 libsbc.so=1-64
libldacBT_enc.so=2-64 libfreeaptx.so=0-64 libfdk-aac.so=2-64
libwebrtc_audio_processing.so=1-64
Optional Deps : pipewire-docs: Documentation
pipewire-media-session: Default session manager [installed]
pipewire-alsa: ALSA configuration [installed]
pipewire-jack: JACK support [installed]
pipewire-pulse: PulseAudio replacement
gst-plugin-pipewire: GStreamer support [installed]
pipewire-zeroconf: Zeroconf support
Required By : gst-plugin-pipewire kwin pipewire-jack pipewire-media-session
telegram-desktop wireplumber xdg-desktop-portal
Optional For : google-chrome
Conflicts With : None
Replaces : None
Installed Size : 6.57 MiB
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date : Thursday 05 August 2021 09:36:50 PM
Install Date : Friday 06 August 2021 09:09:20 AM
Install Reason : Installed as a dependency for another package
Install Script : Yes
Validated By : Signature
[root@aaryan-latitudee6420 aaryan]# pacman -Qi pulseaudio
Version : 15.0-1
Description : A featureful, general-purpose sound server
URL : https://www.freedesktop.org/wiki/Software/PulseAudio/
Licenses : GPL
Groups : None
Provides : None
Depends On : libpulse=15.0-1 rtkit libltdl speexdsp tdb orc libsoxr
webrtc-audio-processing libxtst
Optional Deps : pulseaudio-alsa: ALSA configuration (recommended) [installed]
pulseaudio-zeroconf: Zeroconf support [installed]
pulseaudio-lirc: IR (lirc) support [installed]
pulseaudio-jack: Jack support [installed]
pulseaudio-bluetooth: Bluetooth support [installed]
pulseaudio-equalizer: Graphical equalizer [installed]
pulseaudio-rtp: RTP and RAOP support [installed]
Required By : plasma-pa pulseaudio-bluetooth pulseaudio-equalizer pulseaudio-jack
pulseaudio-lirc pulseaudio-rtp pulseaudio-support pulseaudio-zeroconf
Optional For : bluetooth-autoconnect firedragon phonon-qt5 phonon-qt5-gstreamer
Replaces : pulseaudio-xen<=9.0 pulseaudio-gconf<=11.1
Installed Size : 5.81 MiB
Build Date : Wednesday 28 July 2021 05:44:50 PM
Install Date : Tuesday 03 August 2021 05:53:11 PM
tried to uninstall it but didn't worked
╭─aaryan@aaryan in ~ took 2s
[🔴] × sudo pacman -R pulseaudio (base)
checking dependencies...
:: removing pulseaudio breaks dependency 'pulseaudio' required by plasma-pa
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-bluetooth
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-equalizer
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-jack
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-lirc
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-rtp
:: removing pulseaudio breaks dependency 'pulseaudio' required by pulseaudio-support
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-zeroconf
You can only have one pipewire or pulseaudio, it's wierd no conflict flags go off
i tried uninstalling pulseaudio , entire sound options are gone, no audio control nothing is there then i have to restore the system using timeshift.
it is there
pacman -Qi pipewire (base)
Licenses : MIT LGPL
Groups : None
Depends On : rtkit alsa-card-profiles libdbus-1.so=3-64 libncursesw.so=6-64 libsndfile.so=1-64
libudev.so=1-64 libusb-1.0.so=0-64 libasound.so=2-64 libsystemd.so=0-64
libbluetooth.so=3-64 libsbc.so=1-64 libldacBT_enc.so=2-64 libfreeaptx.so=0-64
libfdk-aac.so=2-64 libwebrtc_audio_processing.so=1-64
Required By : gst-plugin-pipewire kwin pipewire-jack pipewire-media-session telegram-desktop
Replaces : None
If it were you wouldn't lose your audio control. Reinstall
I have removed the pulseaudio then everything is gone related to audio. i tried searching for solution i found nothing. Still at this point pipewire was there but still no audio. I did system restore and then pulseaudio -k audio is working again but if i do restart the system again i have to execute the command pulseaudio -k or the sound won't play.
There are a few fishy things here.
It's not possible to have pulseaudio by default because according to my info KDE uses pipwire. And you deny installing
2nd there is no way to have them both install without conflicting.
You need to enable pulseaudio service in systemd, Google how to do that.
I tried as you suggested but facing this issue now.
Running PulseAudio as a system-wide service has advantages -- you can play audio without having logged on, multiple users can play audio on the same audio gear, and music daemons like MPD won't fight for the audio device with PulseAudio. Here's how.
╭─root@aaryan in /etc/systemd/system
╰─λ systemctl --system enable pulseaudio.service
Created symlink /etc/systemd/system/multi-user.target.wants/pulseaudio.service → /etc/systemd/system/pulseaudio.service.
╭─root@aaryan in /etc/systemd/system took 1s
╰─λ systemctl --system start pulseaudio.service
Failed to start pulseaudio.service: Unit pulseaudio.service has a bad unit file setting.
See system logs and 'systemctl status pulseaudio.service' for details.
╭─root@aaryan in /etc/systemd/system took 29ms
[🔴] × systemctl --system status pulseaudio.service
○ pulseaudio.service - PulseAudio system server
Loaded: bad-setting (Reason: Unit pulseaudio.service has a bad unit file setting.)
Active: inactive (dead)
Aug 10 23:48:37 aaryan-latitudee6420 systemd[1]: /etc/systemd/system/pulseaudio.service:6: Unknown key name '>
Aug 10 23:48:37 aaryan-latitudee6420 systemd[1]: pulseaudio.service: Service has no ExecStart=, ExecStop=, or>
lines 1-6/6 (END)
Bro
10 August 2021 23:13
16
Enable and start the pulseaudio server in systemd.
dalto
10 August 2021 23:27
17
This is not true at all. You can both installed without conflicting.
For example:
yay -Q | grep -E "pipewire|pulse"
libpulse 15.0-1
pipewire 1:0.3.33-1
pulseaudio 15.0-1
pulseaudio-alsa 1:1.2.5-2
pulseaudio-qt 1.3-1
If you have pipewire and don't want pulseaudio then you also want pipewire-pulse .
This is, "pipewire + pipewire-pulse" OR "pulseaudio"
Bro
11 August 2021 03:19
19
Replace pipewire-support with pulseaudio-support, and Bob's yer Aunt.
Thanks everyone, The Problem is solved now, as suggested by @regularCoder need to enable pulseaudio service in systemd. I did it using the help from this website https://rudd-o.com/linux-and-free-software/how-to-make-pulseaudio-run-once-at-boot-for-all-your-users
