Trying to figure out why there is such a pop before the audio card plays a sound. If I keep the sound card active by just streaming music to it, then the rest of the sounds from the PC and VIMS are fine. If I do not keep the card active then there is a pop, as if it is initilizing the card each time it wants to play sound. Get’s quite annoying with e-mail etc streaming in. It is as if the card goes to sleep after ever sound it plays.
So for now I just keep spotify playing 24x7 as 1%. Off to searching Arch forums etc ;-). Anyone have an idea? Would love to just music through the 5 speakers, you can see poor woofers bounce a bit before just playing a notification ;-).
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=85d10ba7-1da5-4b61-a934-a0dd37c75c5e rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 vfio_pci.ids=10de:1c82,10de:0fb9
pcie_acs_override=downstream,multifunction video=efifb:off iommu=pt
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS WIFI v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 1801 date: 12/26/2022
Device-1: hid-0003:256F:C62E.0002-battery model: 3Dconnexion SpaceMouse
Wireless serial: N/A charge: N/A status: discharging
Info: model: 11th Gen Intel Core i9-11900KF socket: LGA1200 bits: 64
type: MT MCP arch: Rocket Lake gen: core 11 level: v4 note: check
built: 2021+ process: Intel 14nm family: 6 model-id: 0xA7 (167)
stepping: 1 microcode: 0x59
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4742 high: 4800 min/max: 800/5100:5300
base/boost: 3465/8500 scaling: driver: intel_pstate governor: powersave
volts: 0.9 V ext-clock: 100 MHz cores: 1: 4800 2: 4790 3: 4800 4: 4792
5: 4800 6: 4800 7: 3915 8: 4800 9: 4800 10: 4799 11: 4799 12: 4780
13: 4800 14: 4800 15: 4800 16: 4800 bogomips: 112128
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: ZOTAC
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e87 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
non-free: 535.xx+ status: current (as of 2023-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-3: Adomax Nuroum C40 driver: usbfs type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:4 chip-ID: 0627:a6bf
Device-4: Logitech HD Pro Webcam C920 driver: usbfs type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.4.2:5 chip-ID: 046d:082d
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,vfio-pci display-ID: :0
Screen-1: 0 s-res: 8320x1440 s-dpi: 92 s-size: 2297x393mm (90.43x15.47")
s-diag: 2330mm (91.75")
Monitor-1: DP-1 pos: 2-4 res: 1920x1080 hz: 60 dpi: 82
Monitor-2: DP-3 pos: 2-2 res: 1920x1080 hz: 60 dpi: 82
Monitor-3: DP-4 pos: primary,1-3 res: 2560x1440 dpi: 93
size: 698x392mm (27.48x15.43") diag: 801mm (31.52") modes: N/A
Monitor-4: None-1-1 size-res: N/A modes: N/A
Monitor-5: USB-C-0 pos: 2-1 res: 1920x1080 dpi: 163
size: 300x260mm (11.81x10.24") diag: 397mm (15.63") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
2080/PCIe/SSE2 direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: ZOTAC driver: snd_hda_intel
Device-3: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:0fb9
Device-4: Adomax Nuroum C40 driver: usbfs type: USB rev: 2.0
Device-5: Giga-Byte ESS SABRE HiFi USB Audio Device
lanes: 1 mode: 2.0 bus-ID: 1-12.2:15 chip-ID: 0414:a00c class-ID: 0300
Device-6: Giga-Byte USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12.3:18 chip-ID: 0414:a008
Device-7: Logitech HD Pro Webcam C920 driver: usbfs type: USB rev: 2.0
Device-8: GN Netcom Jabra Engage 75 driver: usbfs type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.4.3:6 chip-ID: 0b0e:1112
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.79 status: n/a (root, process) with:
IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet5 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:17 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 20.49 TiB used: 12.95 TiB (63.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 43.9 C
SMART: yes health: PASSED on: 1y 148d 10h cycles: 1,369
read-units: 82,971,794 [42.4 TB] written-units: 55,821,243 [28.5 TB]
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 31.9 C scheme: MBR
SMART: yes health: PASSED on: 1y 219d 18h cycles: 424
read-units: 8,797,418 [4.50 TB] written-units: 11,140,153 [5.70 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 00RL temp: 43 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 91d 22h cycles: 353
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
fw-rev: 00RL temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 281d 19h cycles: 580
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 512G
size: 476.94 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1000 temp: 38 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 3y 194d 19h cycles: 599
read: 1.4 MiB written: 1.6 MiB
ID-6: /dev/sdd maj-min: 8:48 vendor: Silicon Power model: SPCC M.2 SSD
size: 119.24 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B0 temp: 40 C
SMART: yes state: enabled health: PASSED on: 1y 181d 7h cycles: 678
read: 10.5 MiB written: 11.9 MiB
ID-7: /dev/sde maj-min: 8:64 vendor: ASMedia model: T ASM236X NVME
size: 119.24 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
drive serial: <filter> fw-rev: E8FK11.C temp: 48 Celsius C scheme: GPT
SMART: yes health: PASSED on: 127d 18h cycles: 542
read-units: 2,509,710 [1.28 TB] written-units: 2,676,225 [1.37 TB]
ID-8: /dev/sdf maj-min: 8:80 vendor: Samsung model: SSD 860 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0001
drive-rev: RVT04B6Q temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 83d 13h cycles: 337
written: 2.3 TiB
ID-9: /dev/sdg maj-min: 8:96 vendor: Samsung model: SSD 860 EVO 500GB
sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0001
drive-rev: RVT02B6Q temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 369d 10h cycles: 113
written: 15.06 TiB
ID-10: /dev/sdh maj-min: 8:112 vendor: Western Digital
model: WD40EFRX-68N32N0 family: Red size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 3004 drive-rev: 82.00A82 temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 107d 3h cycles: 3277
ID-11: /dev/sdi maj-min: 8:128 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: TB08 scheme: GPT
ID-12: /dev/sdj maj-min: 8:144 vendor: Seagate model: Expansion SW
fw-rev: 1801 scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-13: /dev/sdk maj-min: 8:160 vendor: Seagate model: Backup+ Hub BK
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: D781 scheme: GPT
ID-14: /dev/sdn maj-min: 8:208 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
ID-1: / raw-size: 159.23 GiB size: 159.23 GiB (100.00%)
used: 58.09 GiB (36.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:8
used: 25.9 MiB (27.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:4
ID-3: /home raw-size: 159.23 GiB size: 159.23 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 159.23 GiB size: 159.23 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 159.23 GiB size: 159.23 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: zram size: 31.15 GiB used: 296 MiB (0.9%) priority: 100
System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
Processes: 453 Uptime: 19h 38m wakeups: 5 Memory: total: 32 GiB
available: 31.15 GiB used: 14.98 GiB (48.1%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1700 libs: 423
tools: gnome-software,octopi,pamac,paru Shell: Bash (sudo) v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date: 2023-08-25
Last full system update: 2023-09-14 ↻
Windows dual boot: Yes
