From time to time, my audio keeps cutting out randomly while I'm in the middle of something I ought to be hearing. In the Volume Control window on the Playback tab, I found that when this happens the setting has been changed from Starship/Matisse HD Audio Controller Analog Stereo (my speakers) to Navi 21/23 HDMI/DP Audio Controller Digital Stereo HDMI 5 (my monitor and its built-in speakers) for all the windows. I have already set the volume of the monitor to 0 both in directly in the monitor through the physical buttons and in the Output Devices tab of Volume Control AND hit the Mute Audio icon. Despite this, several times within a day has my audio cut out because Garuda, through no provocation, switched to using the monitor as the playback device for all my active windows.
Kernel: 5.15.81-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=edc63662-0e17-4e76-aa70-b1e6f5bfc98d rw [email protected]
resume=UUID=6308b6d5-0e45-4af9-b736-5432b977f5f7 loglevel=3
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.B0
date: 08/11/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3821 high: 4088 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3770 2: 4088
3: 3926 4: 3747 5: 3817 6: 3733 7: 3737 8: 3997 9: 3751 10: 3971 11: 3740
12: 3674 13: 3837 14: 3694 15: 3947 16: 3715 bogomips: 121596
prctl and seccomp
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 2d:00.0
chip-ID: 1002:73df class-ID: 0300
compositor: xfwm v: 4.16.1 driver: X: loaded: amdgpu
Monitor-1: DP-3 mapped: DisplayPort-2 model: ViewSonic XG2401 SERIES
serial: <filter> built: 2017 res: 1920x1080 hz: 120 dpi: 92 gamma: 1.2
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 14.0.6 DRM 3.42 5.15.81-1-lts) direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.15.81-1-lts running: yes
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 145.44 GiB (7.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Slim
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 1707 scheme: GPT
ID-1: / raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
used: 56.42 GiB (6.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
ID-4: /var/log raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.27 GiB used: 890.2 MiB (2.8%)
ID-2: swap-2 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 50.5 C mobo: N/A gpu: amdgpu temp: 57.0 C
mem: 56.0 C
Processes: 392 Uptime: 13h 0m wakeups: 0 Memory: 31.27 GiB
used: 5.87 GiB (18.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1557
libs: 489 tools: pamac,paru,yay Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-03
Last full system update: 2022-12-04 ↻
