It’s happening since the day I installed Garuda Linux Dr460nized Gaming edition and it’s becoming really annoying.
The exact issue is as follows:
I use my headphones all the time and no other audio device is connected. And while using the computer, it just randomly decides to switch the audio output from “Line Out” to “Headphones(unplugged)” and the audio output just totally cuts off. It gets really annoying when I’m using anything in fullscreen as I have to get out of fullscreen and change the audio output back to Line out and then continue it. Occasionally, it reverts back to Line Out from Headphones(unplugged) after some seconds (sometimes minutes) which lessens my anger.
I cannot re-install Garuda as I have important files here which are very large in size and also my games which I would avoid re-installing due to their massive size (GTA V).
I searched on the internet and to my luck I did not find anything that could fix this issue.
Any help is appreciated.
Here’s the inxi :–
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bb5ab862-f9e2-487f-9cef-657cf07d56fe rw rootflags=subvol=@
quiet resume=UUID=4435ecd6-beb5-45ab-acfd-8cd8092b143b loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: N/A model: ZRD1105 v: REV V52.9
serial: <superuser required> UEFI: American Megatrends v: 5.12
date: 02/15/2023
Info: model: Intel Core i3-7100 bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2646 high: 3900 min/max: 800/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3900 2: 3900 3: 800
4: 1985 bogomips: 31199
Device-1: Intel HD Graphics 630 driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: DP-1
empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
s-diag: 414mm (16.31")
Monitor-1: DP-1 model: DP2VGA V300 serial: <filter> built: 2015
res: 1366x768 hz: 60 dpi: 136 gamma: 1.2 size: 256x192mm (10.08x7.56")
diag: 690mm (27.2") ratio: 16:9 modes: max: 1024x768 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 11 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.3.1-arch1.1
device-ID: 8086:5912 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.1-arch1.1 (LLVM
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
IF-ID-1: wlp0s20f0u7i2 state: up mac: <filter>
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter driver: btusb,rtl8xxxu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3
chip-ID: 0bda:b720 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 238.47 GiB used: 154.41 GiB (64.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 11004101 temp: 52.9 C
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 154.41 GiB (67.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 23.2 MiB (0.3%) priority: 100
System Temperatures: cpu: 46.0 C pch: 45.5 C mobo: N/A
Processes: 244 Uptime: 1m wakeups: 0 Memory: total: 8 GiB
available: 7.68 GiB used: 3.3 GiB (43.0%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1824 libs: 556
tools: gnome-software,octopi,pamac,paru,yay Shell: fish v: 3.6.4
Garuda (2.6.21-1):
System install date: 2023-11-06
Last full system update: 2023-12-21
