hello new user here, hope this is correct. audio will only play through left channel. using headphones and desktop speakers. for the past few months all was fine until the other day after turning my system on i noticed my audio wasn't playing properly. any advice would be helpful on how to fix the issue. thanks in advance. if i am going about this in the wrong way on this forum than let me know.
λ garuda-inxi
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3df45e73-b91d-4da9-ad12-d44181e9d572 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
ID-1: hidpp_battery_0 charge: 63% condition: N/A volts: 3.9 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
Device-1: hid-dc:2c:26:db:b6:43-battery model: Keychron K6 serial: N/A
charge: N/A status: discharging
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3733 high: 4358 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3670 2: 3599
3: 4170 4: 3887 5: 3599 6: 3659 7: 3749 8: 3656 9: 3591 10: 3599 11: 3713
12: 3684 13: 4358 14: 3598 15: 3600 16: 3600 bogomips: 124806
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA 1
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0a:00.0
chip-ID: 1002:731f class-ID: 0300
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung S34J55x
serial: <filter> built: 2019 res: 3440x1440 hz: 75 dpi: 110 gamma: 1.2
size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.46
5.18.9-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 3-4.1.2:7 pcie: gen: 4 chip-ID: 262a:9023 speed: 16 GT/s
class-ID: 0102 lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab38
Device-3: SAVITECH SA9023 audio controller type: USB
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
bus-ID: 1-5:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 12.76 TiB used: 466.78 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT30Q.1
temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 model: PCIe SSD size: 953.87 GiB
type: SSD serial: <filter> rev: ECFM13.3 temp: 26.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD easystore 25FB size: 10.91 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 3007 scheme: GPT
ID-1: / raw-size: 929.1 GiB size: 929.1 GiB (100.00%)
used: 466.75 GiB (50.2%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:6
used: 26 MiB (8.7%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-3: /home raw-size: 929.1 GiB size: 929.1 GiB (100.00%)
ID-4: /var/log raw-size: 929.1 GiB size: 929.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 929.1 GiB size: 929.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 607
Processes: 395 Uptime: 1d 6m wakeups: 84 Memory: 31.26 GiB
used: 6.4 GiB (20.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2152
lib: 574 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-07-30
Last full system update: 2022-07-05
